Author Subject: rear suspension help
cornish_pug
Got a knock on back end again Hmm had a look and it's coming from the beam tube I presume. I rebuilt it 3 years ago with new shafts, bearings seals etc. I can't see any excessive play though. The noise is very noticeable with handbrake on, not so much without. Also under braking u can hear it. If I'm right in saying I thing the inner bearing is f**ked, but definitely no creeking noises. Just a loud knock when I push the back end down with handbrake on.
What do you think guys?
Team Diesel
Posted 7th Sep 2014 at 18:44
highly unlikely its the bearings, check the beam mountings and the caliper bolts.
Posted 7th Sep 2014 at 19:06
cornish_pug
Checked the mountings and they seem good though Wink
Team Diesel
Posted 7th Sep 2014 at 19:54
cornish_pug
How much clearence is there between the arb and the hole in the swing arm shaft?
Team Diesel
Posted 7th Sep 2014 at 19:57
shouldn't be any if you fitted the bushes...
Posted 7th Sep 2014 at 19:58
cornish_pug
I'm talking about the hole in the inner part of the shaft.
Team Diesel
Posted 7th Sep 2014 at 20:21
osm2121
Yes, shouldnt be any clearence, it has some rubber bushes inside to seal and prevent that clearance.
That black rubber:
PD: Thats a good example of how NOT to mount it Big grin
Posted 9th Sep 2014 at 22:54
cornish_pug
The noise seems to be coming from where the inner bearing is pressed to in the beam tube
Team Diesel
Posted 10th Sep 2014 at 19:18
jord294
In that case, did you fit the inner bearings to correct depth ??
Posted 10th Sep 2014 at 21:27
cornish_pug
As far as I can remember, think the figure was in the faq guide.
Team Diesel
Posted 10th Sep 2014 at 22:19
osm2121
Brake pads??? Having some movement?
Does it have excesive camber? Tried pushing it sideways also? If it´s the inner bearing, by pushing it sideways it should also do that sound I guess
Posted 11th Sep 2014 at 00:14
cornish_pug
No, just sideways movement you can here the noise. My camber hasn't changed since the rebuild.
Team Diesel
Posted 11th Sep 2014 at 18:32
