Author Subject: gear linkage pivot arm
pugheaven
Not sure if that's what it's called.....
Ordered a new one from pug as my old one was worn, when I ordered it I asked about the 2 top hat Bush's, today I got round to picking the items up 😊
However the new arm came with some plastic bush's fitted as shown in the right hand pic
I tried the centre tube bearing (shown in the left picture) into the new top hat bushs but its too wide so won't fit however it does fit in the new arm with the plastic bush's that came fitted to the arm
Do Peugeot do two types of arms?
If they do I'm still confused as the old tube doesn't fit in the new top hats ?!?
Posted 21st Aug 2014 at 18:09
midlife
I've a setup that will do away with the rubber ball if you're interested, drop me a pm if you want to talk price.
Check out below
http://s89.photobucket.com/user/midlife_01/library/gearbox
Cool
Team 330™Cool
Team "no front end or engine"
Posted 21st Aug 2014 at 18:31
Redesigned arm by pug dude
Posted 21st Aug 2014 at 18:52
If you extend the small ball on the arm you can shorten the gear throw as well dude ?
Posted 21st Aug 2014 at 18:53
pugheaven
I know about extending the arm, so if its a redesigned arm how do you assemble it? And how come the diagram on peugeots computer showed these bush's.... is there a new thinner outer diameter sleeve/tube for theses bushs?
Posted 21st Aug 2014 at 19:20
No idea dude ? Never changed to the set up
Posted 21st Aug 2014 at 19:01
Do you even need the top hat bushes ? Or the the tube ? Have you tried fitting it ?
Posted 21st Aug 2014 at 19:02
pugheaven
Yes iv tried fitting it, defo need the tube but with the tube inside the plastic bush's there is still loads of play so I'm guessing it's not right
Back to Peugeot tomorrow to find out what's going on
Posted 21st Aug 2014 at 19:06
What part number have you got dude ?
Posted 21st Aug 2014 at 19:11
pugheaven
The arm is 244971 and the bush's are 217534
Posted 21st Aug 2014 at 19:14
miki4
Pugheaven, how have you solved the problem? Currently going through the same s**t. Bought two of those brass-like metal bushes and the inner diameter is too small to fit the tube. Will buy a new arm and a new tube and hope it will fit with the right amount of play.
Posted 27th Nov 2016 at 23:19
mocinim
Where is the play chap i presume your fitting the top washer ??
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 28th Nov 2016 at 00:41
You must have a phase 2 as Service Box shows the arm not available but is for the phase 3 which are different part numbers with different dimensions shown for the tube.
Must be an improvement of some kind.
Posted 28th Nov 2016 at 02:05
sounds like you need to order the tube as well.
Posted 28th Nov 2016 at 08:12
miki4
The pivot arm with the rubber ball on it is available and there are no differences between the phases according to Service Box.
Posted 28th Nov 2016 at 11:56
My phase 2 gives part numbers different from those quoted when I use my VIN so are different.
Posted 28th Nov 2016 at 20:28
