displaying posts 26 to 50 of 135
Pages (6): 1 [2] 3 .. last
Author Subject: Overheating
Chr1sch
I'll check first thing, thanks again :-)
Posted 14th Aug 2014 at 21:46
aaron6
cully wrote:
if it has AC you should have two fans
slow speed is two fans in series fast speed is two in parrellel
if one is missing you wont get slow speed!
This is exactly what I was trying to say. Smile
Posted 14th Aug 2014 at 22:49
Chr1sch
Ok so one was hiding behind the oil cooler, I do have 2, however if can't find any scenario where both are on? (Incl unplugging brown clip)
Posted 15th Aug 2014 at 20:19
cully
i would suggest trying to test the one fan that is not working as i suspect it is faulty Wink
Posted 15th Aug 2014 at 20:35
aaron6
Yep if both don't come on when the brown sensor is unplugged then you most likely have a faulty fan. You need to get it fixed so you have the slow speed fans. Do the ac bridge trick and at least you can manually turn them on to max speed whenever you want.
Posted 15th Aug 2014 at 21:37
Chr1sch
Cool thanks gents, I guess I need to source a new fan then!
Posted 15th Aug 2014 at 23:27
cully
to use A/C Button for Fan override
Disconnect A/c pump electricly
Unplug A/c Pressure switch
then bridge pins in A/c Pressure switch loom side plug, one or the other not both Wink
Bridge pins 1&2 = low speed from both fans
Bridge pins 1&3 = high speed from both fans
Posted 16th Aug 2014 at 00:00
aaron6
Brilliant cully. Thumbs up
Posted 16th Aug 2014 at 07:36
Chr1sch
Fantastic thank you!
Posted 16th Aug 2014 at 08:27
Chr1sch
Post #35
Ok so it's been an absolute bas**rd but....I finally have the duff fan motor off and I'm ready to replace it
Dad came round with his multimeter and we tested the plug, it has 2 pins, one positive, one negative I assumed?? We could not get any voltage readings from it that way at all, however we got an instant. 12v if earthed elsewhere, are the fans earthed?
To avioid confusion we got voltage when pulling the brown plug out, one fan going nuts, other dead... Do they use the same earth or could I have a perfectly good fan with a dodgy earth? (If it is earthed via plug)
Posted 15th Sep 2014 at 08:13
Post #36
Fan cowling is plastic....
check the small multiplug on the corner, cant remember if the earths meet before the plug, if they dont then it could be the plug, if they do there might be a break in the wiring if there isnt a circuit from the fan plug to earth.
Posted 15th Sep 2014 at 08:38
Chr1sch
Post #37
Thanks, so the plug should be earthed? Ie one pin positive, one negative?
If so I defo only have an earth at one fan!? (So there must be an individual earth for each?)
Is that all correct?
Posted 15th Sep 2014 at 17:22
cully
Post #38
the relays switch the wiring so you may not have any connection if the relays arnt powered
if you have the duff fan off put 12v across the socket on the motor see if it spins
hold onto it tight as it starts with quite a kick
Posted 15th Sep 2014 at 22:50
Chr1sch
Post #39
Is there a relay per fan? Doesn't appear that way in the manual but then as you can tell I'm learning lol
Posted 16th Sep 2014 at 07:52
cully
Post #40
there should be 3 relays and a fan controller Bitron box on a GTI6 (NOT A RALLYE)
1 relay switches the power to the fans
2-3 relay switches the wiring between series and parallel fans to get your two speeds
the bitron box controls all of the above taking signals from CTS and A/C switches
below is a wiring drawing with the fan loom drawing to the first plug Wink
this is for a GTI6 Not a Rallye
Posted 16th Sep 2014 at 11:05
Chr1sch
Post #41
Right ok thanks, I hope I haven't just removed a perfectly decent fan and have a duff relay :-s
Where are the 3 relays you describe above?
I'm embarrassed to say I just cannot Decipher that diagram...
Is there an easy way to test a relay?
Posted 16th Sep 2014 at 11:12
Chr1sch
Post #42
As an FYI I removed the brown plug and only one fan comes on, I was told this meant defo a dead fan?!
Posted 16th Sep 2014 at 11:13
cully
Post #43
i would say you have a dead fan yes
the three relays are in the triangle box between the two fans at the top of the plastic cowl
Posted 16th Sep 2014 at 12:21
Chr1sch
Post #44
Ok i could actually scream at this point, i've just no idea why i only have 1 fan working..
Here's what ive done:
1) Pull out brown plug
2) Right hand fan not coming on, remove....
3) Test plug for motor - very difficult to get 12v on the multimetre, with the earth else where on the car (e.g slam panel) 12v there, if just using the 2 terminals, no 12v.
4) Replaced duff motor...
5) Cry, new motor doesnt work either....(clearly original fan is fine, but i've buggered it now lol)
6) Open newly discovered box with relays (thanks cully) - 2 green at top, one black below
7) Swap green relays over (just in case they correspond to right and left) - makes no difference, right not coming on
8) pull out black relay below, terminals all manky, clean up, plug back in...
9) No chuffing difference
I've got a track day coming up and no fecking clue how to fix this, arrrgghhhh any ideas gents, i'm stumped. The earth thing is clearly odd but i've unclipped the motor plug and traced the wiring back to the relays at the top of the fan cowling and its all fine...
Help!
Posted 16th Sep 2014 at 16:30
Post #45
Fine as in looks ok or fine as in you have actually checked to see why there is no earth from that plug?
Posted 16th Sep 2014 at 17:53
Chr1sch
Post #46
Haha indeed, it's virtually impossible to tell where it ends, I think it ends at the relay so will continuity test tomorrow...
Posted 16th Sep 2014 at 19:58
Post #47
well there's a diagram above...
Posted 16th Sep 2014 at 20:08
Chr1sch
Post #48
It may as well be written in Swahili i have no idea what I'm looking at...
Posted 16th Sep 2014 at 21:18
Post #49
wires n stuff.
Posted 16th Sep 2014 at 22:16
Chr1sch
Post #50
In simple terms what does that diagram illustrate in terms of where the wire ends?
Posted 16th Sep 2014 at 22:41
