displaying posts 76 to 100 of 164
Pages (7): first .. 3 [4] 5 .. last
Author Subject: Newbie 306Gti-6 Owner (soon)
MisterGTR
Post #76
No sorry not the air box. The snorkel air inlet thing that goes over the radiator to the air box.
Posted 31st Aug 2014 at 10:24
Lecktorious
aka G.
Post #77
What Peugeot dealers are you going to mate? I used Robin's & Day on Minerva Street, their parts department know their stuff and generally hold a good stock of consumables for the 306, and if not they can normally get a hold of them quite quickly.
As for wishing the steering wheel was a bit closer, I'd recommend getting a dished steering wheel with a boss to suit. Really makes a difference Yes
'98 Nile Blue 306 GTi 6
Posted 31st Aug 2014 at 20:24
MisterGTR
Post #78
Yeah those are the guys I'm using. It's pretty handy for me as I'm in Anniesland.
Need to pick up lower hose this week. Also need to order all the screws, brackets, etc that I'm mangling.
I've removed the condenser, radiator and dryer. Got stripped heads on the brackets holding on the lower ac pipes. So need to get them off. Probably use a chisel!
I have new lower ac pipes. But might take them to pirtek to rubber versions made.
I'll get round to the steering wheel in due course. But thank you for heads up
MisterGTR has attached the following image:
Posted 1st Sep 2014 at 08:36
MisterGTR
Post #79
My radiator has seen better days. Amazing amount of crap in back there too. Including cigarette butts.
One of the fun things is all the rust dropping into my eyes while working.
Found a good image resizer so can post photos here now
Posted 1st Sep 2014 at 08:40
MisterGTR
Post #80
This is the dryer that came off
Posted 1st Sep 2014 at 09:37
MisterGTR
Post #81
This is the condenser. Both radiator and condenser wetter weepy according to ac guys. Having taken them off I'm glad yo be replacing.
Posted 1st Sep 2014 at 09:39
MisterGTR
Post #82
Okay so i finally removed the bit of the air con pipe held in by the spring clip. I'm wonder whether it was actually held in at all, because i hadn't actually removed it from the rubber bung next to the radiator and when i did that it came out no problem! Doh! Hence i'm changing my avatar profile.
It's been a while since i had the chance to work on the car so i'm hoping i remember where i put all teh bits!
Anyway, all good. Got new screws to put the new ac pipes in place. I dremmelled the old ones out!
I broke the white plastic bit that holds the fuel pipes to the engine bay next to the strut (so ordered that this morning) and hopefully i have all the bits i need to put the car back together on Wed! (need to get some coolant) I'm then expecting the ac leak like a mofo so will take to Halfords for recharging.
I change the air filter for a K&N and i'll change the spark plugs once i've got her running again.
After that i will probably take her for a long drive so i can change the gear box oil and then figure out what bits i need to tighten up the chassis. I keep flicking between B12 kit and polybushes all about once (with a garage doing the rear end) or doing it bit by bit in terms of putting new standard bushes in and the all the other wobbly bits. The issue i have is it's starting to get cold so working on the car is becoming less attractive to sitting in a warm pub! Smile
Also on the look out for 16" wheels. I'll keep the 15" cyclones for track days as they currently have mismatched tyres and when they are done getting 15" tyres will be cheaper.
What do you guys think about these? http://www.ebay.co.uk/itm/16-oz-ultraleggera-alloy-wheels-citroen-peugeot-4x108-pcd-/321549286662?ssPageName=ADME:B:BODO:UK:1
I used to run Superleggeras on my S3 years ago and like them lots.
More to come soon i hope!
Posted 13th Oct 2014 at 14:44
MisterGTR
Post #83
Ignore that link to those wheels....wrong size of tyres!
Posted 13th Oct 2014 at 15:29
Cjwatson27
Post #84
Think theres a couple of sets of pro 1.2 in the for sale section buddy
Posted 13th Oct 2014 at 17:10
MisterGTR
Post #85
Cheers - yeh Phil's set sold before i got my act togther and Jord's dont' have any pics. But ta Thumbs up
Posted 13th Oct 2014 at 17:15
MisterGTR
Post #86
So i took a day off work today to get the car back on 4 wheels.
First issue. The bottom AC pipe has a different bracket (see photo) and so i had to spend an hour hunting down 2 suitable screws. Finally got that sorted.
Posted 15th Oct 2014 at 18:20
MisterGTR
Post #87
Next issue was opening the condesor box to finally put it all back together and i get this a bent item....and quite a few of the metal bits bent and broken.....so the saga continues! Need to refund this and get a new one.
Posted 15th Oct 2014 at 18:23
orta
Post #88
Good work buddy. Think u need a proper project thread for this work now!
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 15th Oct 2014 at 21:10
MisterGTR
Post #89
You're right,. Wheni get her back running again. I'll start a new thread.
Was a great feeling flicking the switch on the torque wrench to tighten!! Smile
Posted 15th Oct 2014 at 21:47
MisterGTR
Post #90
Okay so spoke to seller of Nissen rad this morning.
He called me up. Was very pleasant. Amazing how much difference good customer service makes. I sent him photos - he spoke to Nissen and called me back
He said the bend was designed as per diagram (see below).
He said the broken fins won't make a huge difference.
He offered me a replacement but said it would be pretty much the same depending on how the couriers handled it.
So wish me luck it's all going back together this weekend!
Posted 16th Oct 2014 at 12:54
MisterGTR
Post #91
Went ahead and bought those OZ wheels above. I had Oz Superleggeras on my Audi S3 that i was my first decent car about 10 years ago. So heart over head.
Bit bizarre because i called up and spoke to the guy on the phone a couple of days ago. Agreed a price, and he said he'd send me a paypal invoice (to avoid ebay fees) and nothing. I had a mate email him last night and he was still trying to punt them. So i ended up just buying them through ebay. Better for me i guess as if they're bent or damaged i can send them back.
What's even more bizarre is that now his seller info has come up having down the deal through ebay is that he's a proper garage.
http://www.garagesdorset.co.uk/contact-us/
I don't get why he just didn't take payment over the phone when i spoke to him!
Ah well, anyone want a set of 205 50 16's?
Or should i just run them?
Also i guess i'll need some bolts and locking nuts?
Posted 17th Oct 2014 at 11:24
MisterGTR
Post #92
Back to wanting to set the car on fire. Spent an hour trying to fit the new radiator. And it just won't fit past the engine. Don't get how it came out if it won't go back. I'm pulled the slam panel as far as I can. Doing this hungover is a very bad idea. Will try and get the kid from my street to help out later in week.
Also just read I should have kept a thermostat from old radiator! Argggghhhh. Time to give up for today. Shame as really nice weather and was looking forward to a drive. Think I'm becoming one of those people who have a car in pieces in their drive and never get it back together!! Lol
Posted 18th Oct 2014 at 16:47
MisterGTR
Post #93
Okay just decided Fek this ( ie lost it Smile) and forced it passed. Woo Hoo. Now to put all the other bits back on.
Posted 18th Oct 2014 at 17:11
RetroPug
Post #94
Big grin That's the spirit. They go in very easily if you remove the inlet manifold but it's in now anyway!
Posted 18th Oct 2014 at 17:52
MisterGTR
Post #95
Cheers Luke.
Check my latest issue!!
Posted 18th Oct 2014 at 18:56
MisterGTR
Post #96
Like an idiot and because of the OH moaning I binned the old radiator and didn't remove the cap!
I guess I'll have to modify the slam panel? Or just buy another rad cap?
Posted 18th Oct 2014 at 18:58
scotzman
Post #97
Buy a new one, cheap enough from Peugeot.
Posted 18th Oct 2014 at 19:22
MisterGTR
Post #98
Cheers I wasn't sure if the pug cap had ears too. I can't remember what it looked like.
Posted 18th Oct 2014 at 19:25
MisterGTR
Post #99
Car is alive!! Not sure where to run the wee pipe from the rad cap. But big thanks to Luke for his help. His suggestion to unclip the radiator and pull it forward, worked a treat.
Now sitting in kwik fit waiting to see if the air con takes a charge. More nervous than I was waiting for exam results!!
Posted 19th Oct 2014 at 14:03
MisterGTR
Post #100
Fail. As this pipe just won't seat. Lost quite a bit of skin levering it in but still pulls out easily. I'm guessing it's a spring clip housing. May take to air con specialist or pug to ask for help.
But at least she's running again. Knocking on full right only issue. Hopefully only due to loose under tray bits I've still to put back properly.
Posted 19th Oct 2014 at 15:12
