Author Subject: Charger squeak?
6waysforward
My car has developed a pulley bearing style squeak.
First thing I did was to whip off the aux belt and start the engine just to make sure it's not the cam belt tensioner.
So after deciding it's not that, I looked into the steering pump which seems fine, the alternator seems fine, the auto tensioner does not sound perfect. Bit like an old roller skate wheel but ok ish. Tensioner bearings on the charger bracket seem ok.
This leads me to think it's the charger. Now you cant spin this fast by hand and the squeaking seems quite loud from that area.
Is there anything I could try with it I.e wd40 behind the pulley or some oil. I thought the traction fluid lubricated the charger pulley bearing? Dunno
Or should I try changing belt tensioners and stuff first. Process of elimination etc?
Posted 2nd Aug 2014 at 18:09
Change the belt or make sure the rollers/tensioner roller is clean.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Aug 2014 at 00:05
rich_w
Make sure nothing has come loose and is throwing the belt alignment out too Smile
Contact Details:
07732 822546
Posted 3rd Aug 2014 at 00:53
ben01328
I know this is a old thread but did you find the issue, mine has just started to squeak near the charger pulley.
cheers
Team Boosted Hyper
Team 330mm Cool
Posted 3rd Oct 2015 at 17:36
6waysforward
Yeh it was the bearings in the pulleys.
Posted 21st Nov 2015 at 18:58
