What length are the hoses? What connectors are at each end? Straight or 90*
Red Rallye - Rolling "restoration"Wishbone Polybushes available
| Author | Subject: mocal oil cooler hose |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Hi, just after some info from those with a cooler fitted.What length are the hoses? What connectors are at each end? Straight or 90* ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
depends where you put it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
depends what cooler you're using and where you fit it. Mocal is either 1/2 or 5/8 bsp, setrab and some others use metric fittings.you need to fit your cooler, plan your pipe route and then measure the lengths. Rally designs is a decent/cheap source for the push fit mocal pipe and fittings. ________________________________________ www.bridgecraftmotorsport.co.uk |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
My 16 row Mocal cooler has -10 Jic fittings and 5/8 hose to the adapter plate, bought all the gear from Merlin Motorsport, Think automotive also sell everything you need. Personally i've used push fit connections and bought the hose in metre lengths and just trim to size, they've worked fine but you can also buy crimp on connections, push fits worked fine for me though. ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
daver6
Ah right I'll mock it up and work it out. Just thought the spare Rallye rad fan space to mount it. I'd thought there'd be some idea of length due to being able to buy a mocal kit. I've got their sandwich plate and 13row cooler with 1/2 bsp ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
