Author Subject: After Pugfest 2014 Misfire !!!!
On way home from Pugfest the 6 started to sound & go as if it was on 3cylinders ...
Managed to get home slowly & checked NGK plugs & Coilpacks & found when No1 coil pack unplugged no differance to Engine ...so must be Coilpack or plug ??? ...Pressure tested Cylinders also !!
Was praying not head gasket !!!!
Anyway when I had a look around Noticed multi plug on No 1 fuel Injector looked more proud than other 3 So pushed it back in only to find it pushed back out !!!!
Turns out underside fixing clip was snapped off & plug wasn't touching correctly ...a quick cable tie around No1 injector & between injector plug two wires ....Sorted .....thankGod .!!!!
To sort 100% would need to sort new plug onto loom ....Thumbs down ....it's good for now ....
Posted 15th Jul 2014 at 19:06
daver6
Another cable tie saves the day!
Wishbone Polybushes available
Posted 15th Jul 2014 at 19:25
Godsend LOL
Posted 15th Jul 2014 at 20:00
Niall
New plug is a piece of p**s to do mate. Get a new one on there before the cable tie slips lol.
Or if its just the metal clip missing, you can nick one from another 2 pin junior timer plug and pop it in
Posted 15th Jul 2014 at 22:30
rallyeash
Your lucky. My car finished it's abused runs with a knackared driveshaft (new the day before) and a dodgy clutch!
309 3dr K20 Type R
Posted 16th Jul 2014 at 18:08
yippeekayay
Too much wheel spin ash... you looked smooth and controlled when I watched you
x box "yippeekayaymofo"
Posted 16th Jul 2014 at 18:43
What brand shafts do you use Ash?
  • Posted 16th Jul 2014 at 18:59
    You mean solder a old one on Thumbs up
    Yep need to LOL
    Posted 16th Jul 2014 at 22:49
    Thank god that wasent me then Ash....how much ?????
    Not complaining about mine now Thumbs up
    Posted 16th Jul 2014 at 22:52
