Author Subject: turbo standard ecu
jarrus464
Hi,
Was looking at some kind of forced induction for my newly purchased gti6,
Engine rebuild is on the cards with some forged goodies,
Has any successfully manged to run a turbo set up using the standard ecu? I know the standard map sensor cant compehend positive pressure, but surely it could be subsituted for a sensor that can read positive pressure,
Arent Map sensors output signals just a voltage that changes depending on what it sees?
And couldnt chip wizards sort that out?
I couldnt find what i wanted in the search function, and hopefully it made sence
Brett
Posted 9th Jul 2014 at 18:30
demondriverdan
AFAIK only Wayne at Chip Wizards can map the standard ECU, not sure if that's a problem for you?
Rallye Race Car
Posted 9th Jul 2014 at 20:28
fatlapit
Aftermarket is the only way
Posted 9th Jul 2014 at 20:39
pugheaven
Not entirely true you could use an escort cosworth ecu and loom
Posted 9th Jul 2014 at 20:55
But to buy one of those and then get that mapped you may as well buy aftermarket.
The MM1AP ecu can only see vacuum not boost so you couldn't do it even with changing the sensor as far as I know.
Posted 9th Jul 2014 at 21:05
jarrus464
Dan,
No its not a problem at all if wayne can do it,
Reason i ask is that hes done all sort of stuff the standard ecu so why not a turbo?
I was thinking the other day, map sensors use voltage as an output signal right? And thats what the ecu sees, so why not use a map sensor thats designed for reading above atmospheric pressure that has an out put signal in the same voltage range as the standard map sensor? Or is there something else that im missing here?
Posted 9th Jul 2014 at 21:42
luke306rallye
Yes Wayne can map the standard ecu to work with turbo conversions. Been done a few times for the TU engines.
Posted 10th Jul 2014 at 06:58
jarrus464
Single plug tu engines use the same ecu?
Posted 10th Jul 2014 at 13:46
J4 does, just not with sequential ignition or injection.
Posted 10th Jul 2014 at 16:26
jarrus464
Ok fair enough, i guess all the sensors stay the same then? Or will I need to change the map sensor out?
Posted 10th Jul 2014 at 18:40
jarrus464
Any one have waynes number so i can call to confirm
Posted 10th Jul 2014 at 22:09
jarrus464
Anyone?
Posted 11th Jul 2014 at 21:48
Ever heard of this awesome thing called google?
Razz
Posted 11th Jul 2014 at 23:51
luke306rallye
wayne@chipwizards.co.uk
Posted 12th Jul 2014 at 07:59
jarrus464
Thanks dude,
Welshpugl.... i didnt actually, might of saved some grief Wink
Posted 13th Jul 2014 at 20:12
