Author Subject: AP Racing calipers
jorg
I have for sale a pair of used AP Racing CP3344 4 pot brake calipers.
They are in need of a refurb and one of the bleed nipples has snapped off, I haven't risked trying the other three so they maybe knackered too.
the mounting hole distance is 130mm
max disc/rotor width possible i would say is 20mm although the bloke i got them off said he was using 22's.
will come with a new set of ferodo 4003 brake pads.
more pictures can be found here
looking for £200 plus delivery
if anyone has any questions please ask and i will do my best to answer Smile
Geoff
306 2.1 S16 Tarmac Rally Car
Posted 23rd Jun 2014 at 18:26
jorg
it is possible for these calipers to fit behind cyclones Yes (although spacers will most likely be required depending on disc/rotor choice)
and the difference in size between the ap caliper and a gti6 caliper
Posted 25th Jun 2014 at 10:56
chrissywood1987@gmail.com
Do these need brackets making up or are they a bolt on part??
Posted 27th Jun 2014 at 01:25
jorg
they will require brackets, the ones pictured are not included as they are for my six pots.
hi-spec can provide blank mounts with the correct mounting centres, just need the hub holes drilling Thumbs up
http://www.hispecbrake.co.uk/UniBrkUL2.html
Posted 27th Jun 2014 at 09:57
Did they fit ok on those rotors with your bracket? Whats the dimensions if that worked Big grin
Posted 27th Jun 2014 at 11:53
jorg
my bracket has the wrong offset for these calipers but can use it to get an idea of what is needed. the rotor in that pic is a 283x22 gti6 item, pretty sure there is a 10mm spacer being used to clear the wheel Hmm will double check in the morning as i'm knee deep in wiring at the moment.
Posted 27th Jun 2014 at 16:17
jorg
bump... still have these and i am open to offers
Geoff
Posted 31st Jan 2015 at 21:25
Pikey176
Hi would you take 150 delivered
Posted 6th Feb 2015 at 18:22
rallyeash
Hmmm.... Do I add them to the list...!
309 3dr K20 Type R
Posted 7th Feb 2015 at 18:15
jorg
provisionally sold Smile
Posted 10th Feb 2015 at 16:01
