Author Subject: Are there different types of rear calipers between years?
DanRM
I've just ordered up a rear brake caliper for my R reg Gti-6, and they've sent me down two saying that there are two for my year and to send 1 back, however looking at them I can't see any difference between the two apart from the part numbers and different coloured handbrake cable holders . Is there actually any difference between the years?
Posted 10th Jun 2014 at 19:17
Piston size maybe ?
Posted 10th Jun 2014 at 19:16
jorg
maybe something to do with the piston sizes Hmm
gti6 rear calipers are 32mm, most of the others are 30mm.
edit: beaten to it by a matter of seconds LOL
306 2.1 S16 Tarmac Rally Car
not for a gti6.
pop the piston dust cover off and check, should be 32mm
Ive seen 2 different types of handbrake lever arms but both grip the cable the same, and as said piston diameter not that they really do a lot anyways lol
Posted 11th Jun 2014 at 13:22
Bosch V Bendix?
Bosch ones on the Renaults etc have a tubular arm wheres the Bendix bradned ones have a flatter arm.
  • Posted 11th Jun 2014 at 13:26
    that's the only difference I've seen in them, they are otherwise identical when I've had them in bits.
    Posted 11th Jun 2014 at 13:42
    Castor_Troy
    Which one is cheaper?
    Posted 11th Jun 2014 at 13:55
    DanRM
    Thanks chaps, ended up being what was suggested. Phoned up the manufacturer and they said one part number was 32mm piston and the other 30mm.
    Posted 12th Jun 2014 at 20:05
