Author Subject: Sold - BTCC modified throttle body
Denis
Bare throttle body without any sensors.
Price £80 + delivery.
Compare to standard:
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 10th Jun 2014 at 22:57
mattgti6phase2
What difference would this give over standard? Just better throttle response?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 7th Jun 2014 at 23:59
Denis
Yes, noticeably better throttle response. Also it is less restrictive to air flow at full throttle (they even removed half of the spindle).
WhiteBMW M140i
Posted 8th Jun 2014 at 00:08
eddy_gti6
Would be handy for my inlet this. Handed my TB in about 6 weeks ago to get done and still waiting!
Posted 8th Jun 2014 at 00:14
rhyds
Why do stuff like this always come up when i have no spare cash!!!
Posted 8th Jun 2014 at 00:39
chiefton
I have a machined throttle body and its awesome.... recommended Thumbs up
cherry rallye daily (the money pit)
Posted 8th Jun 2014 at 11:41
pugheaven
If only my restrictor housing wasn't welded to my tb I would have had this Sad
Posted 8th Jun 2014 at 11:51
walker_texasranger
Can this be run on standard management then? Presume it needs mapping in to realise full potential?
Hilux InvincibleX daily
306 No.13 Doh
Posted 8th Jun 2014 at 14:50
eddy_gti6
Yes it can be ran on standard management, no need for a remap just less restrictive and allows better air flow into the inlet
Posted 8th Jun 2014 at 15:07
walker_texasranger
Straight swap then, just swap your sensors and away you go Dunno
Shifty
306 No.13 Doh
Posted 8th Jun 2014 at 15:09
eddy_gti6
Yep bolt on and away
Posted 8th Jun 2014 at 16:20
Denis
Works fine on standard ECU as it uses MAP sensor as the main load sensor (with an aftermarket ECU you normally use throttle position for load - in which case you have to re-map).
WhiteBMW M140i
Posted 8th Jun 2014 at 22:46
