Hi All, will be changing my standard ECU to a DTA E48, so need to use a DIS ignition coil not the coil on plug type. Does anyone know which plug leads i can use with the XU10J4 head so that it seals the plug bores properly. Also did the phase 1 S16 have DIS ignition or coil on plug or coil pack type.
Thanks.
RallyeP6
