Author Subject: cheap gear oil
Hey all,
My gearbox is getting a bit whiney from cold so i've decided to get some new oil and see how it goes, I figured this might be good for you lot as i thought the price was very cheap!
18 quid delivered for three bottles... (If you are as anal as me and are putting in 2.1)
http://www.nielsencdg.co.uk/acatalog/Total-BV-75W80-Transmission-Manual-Gear-Box-Oil-149980-1L-TOT__149980.html
Posted 28th May 2014 at 10:48
rallyestyle
Thumbs up Good spot Smile
Just Drive It
Posted 28th May 2014 at 11:08
jorg
they have a eBay shop and do good deals on there too!
306 2.1 S16 Tarmac Rally Car
Posted 28th May 2014 at 11:21
You'll probably struggle to get 2.1 litres in though (assuming you actually remove the level plug and fill until it begins to run out, opposed to bunging your pre measured 2.1L in the top and being done with it).
I imagine you'll get to near enough the end of the second bottle with a swig left.
  • Posted 28th May 2014 at 11:50
    last time i did it i had the car perfectly level and removed the plug, then put in 2.1 and no oil had come out, so i just sealed it back up ;/
    Posted 28th May 2014 at 11:54
    scotzman
    If you leave it long enough, 2litres will probably start to trickle from the level check hole. Always has for me.
    Posted 28th May 2014 at 11:57
    As mentioned they're selling on ebay too, greater discount if you buy multiples, in Swansea iirc, so might get a mate to pop in and blag more discount Razz
    I fear however that simply changing the oil will not help at all in this case, its likely to be worn diff bearings or input shaft bearings.
    Also, could just be the release bearing.
    Posted 28th May 2014 at 12:05
    Thats my suspicion too sadly, but we'll see how it goes.
    I guess with all of the abouve (exept a release bearing) its probably just time to get a new box?
    Posted 28th May 2014 at 12:13
    given they're all going to be abused and 15 years old at a minimum, rebuild would be better.
    Posted 28th May 2014 at 12:44
    Yeah sorry thats what i meant really, I've asked miles (via email) of he still does them
    Posted 28th May 2014 at 12:57
    Should have put a spot more in then to take it to the level.
  • Posted 28th May 2014 at 13:02
    Recieved the oil already too. Pretty quick!
    Posted 29th May 2014 at 19:08
    walker_texasranger
    How much was postage on 3 bottles? Can't work out if it falls into the £4.72 bracket they have on the website Hmm
    Hilux InvincibleX daily
    306 No.13 Doh
    Posted 30th May 2014 at 03:39
    I did that then checked it after taking for a short spin and it p**sed out
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 30th May 2014 at 08:08
    I think it was 4.99 walker
    Posted 30th May 2014 at 08:42
    russbez
    Scottish Highlands..... where some people in England think you are 2000 mile away on a remote island
    postage cost made it a waste of time for me Yes
    My Rallye project thread
    Posted 30th May 2014 at 09:23
    But you are 2000 miles away?
    Posted 30th May 2014 at 11:32
    pete_rallye
    Top tip if you don't already is to heat the oil up before filling with a fan heater or something. Makes it miles easier to pour in and it settles to a level much quicker too! Same with draining it, drain it whilst its nice and hot and it'll empty much quicker.
    Lap of the 'ring
    Posted 30th May 2014 at 11:31
    Cool cheers for that.
    Posted 30th May 2014 at 12:31
