Author Subject: Radiator water level
Kevwlsn3
So after changing a radiator I am a bit pataniod about the coolent level inside the radiator.
I fill it up and then take the car out after the engine stops and cools down I look at the water level inside the radiator and it's about 1.5 litres short of being full.
Now I am not daft and I know when the engine and cool plenty gets hot it expands and thus the excess leaves via the top tube. But 1 litre was a little but much I thought.
Is this normal does any one know the usual level of coolent inside the radiator?
Thanks
Kev
Posted 22nd May 2014 at 09:46
scotzman
Might be your rad cap, I had this with mine, leaked about the amount you say and no further.
It was leaking out through the little overflow pipe so I guess the pressure release valve in the cap was f@*ked..
Posted 22nd May 2014 at 10:46
scotzman
Oh, and when you turned it off when the engine was up to temp, you could hear a hiss from the cap.
Posted 22nd May 2014 at 10:49
Kevwlsn3
I shall check , I assumed that when the pressure increased through the temperature the excess escaped out the overflow pipe I take it the level should be full all the time?
Posted 22nd May 2014 at 11:19
Niall
Yep exactly same happened to mine. New rad cap and problem solved Smile
Posted 22nd May 2014 at 12:06
Same on mine New Cap sorted .!!!
Have you bleed all 3points after fitting New Radiator ????
Fitted a Nissan Rad & just read how to do it on FAQ section on here ...
Makes sure you have no Air Locks Thumbs up
Posted 22nd May 2014 at 12:09
chiefton
new cap will sort it Thumbs up
cherry rallye daily (the money pit)
Posted 22nd May 2014 at 12:43
Kevwlsn3
Yea it's bled correctly I happen to have a new cap so will try that today , thanks!
Posted 22nd May 2014 at 12:57
Should it stay full to the brim then or will it lose some out the pressure valve in the cap and find it's own level a but lower??
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd May 2014 at 16:07
jamiek_uk2000
Ah. So I need a new cap as well.
Are they universal?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 22nd May 2014 at 16:54
Pretty much, some are lower pressure, just get one from a dealer, about £15 iitrc.
Posted 22nd May 2014 at 17:56
Puggitt
In my experience, with the plastic rad caps, the atmospheric valve (let air in when cooling) flips over it's self cause the cap to hold absolutely no pressure but I needle used carefully to flip it back can save you so cash Thumbs up
Posted 22nd May 2014 at 19:48
I only use genuine caps on these, they seem to last much better than aftermarket cheaper alternatives.
Posted 22nd May 2014 at 23:09
aaron6
I got a nissens one which seems alright after 4 years. It just feels notchier when your removimg it.
Posted 24th May 2014 at 09:57
Yeah, my Nissens rad came with one all those years ago when I bought it.
I test fitted it and didn't like the feel compared to standard so stayed with the standard one.
Posted 24th May 2014 at 10:05
how the hell would you know stan, you never use the damned thing!
they're meant to be notchy to a certain extent, there's two stages to it.
Posted 24th May 2014 at 10:12
aaron6
It's not that sort of notchy. They dont have the smooth feel to a standard one. I dont have any issues with my nissens one. Plus it looks better.
Posted 24th May 2014 at 11:33
Where should the level be?
Posted 26th May 2014 at 16:28
scotzman
There is a Max and Min marked on the filler.
Posted 26th May 2014 at 16:58
LOL
I still take the cap off every now and again to make sure the coolant is still in there. Yes
Posted 26th May 2014 at 20:14
