Author Subject: fitting Quaife lsd diff into other gearbox
russbez
My gearbox is ready to poop its pants (its last a good few years of abuse Cool)
Started out it was just 3rd gear now i noticed rattles coming from reverse
Anything else i should consider changing when refitting my Diff to my spare gearbox?
any danger in me pressure washing the spare box before i fit anything?
Its pretty dirty looking from sitting for few years, i notice a few open ports/holes
And anyone recommend any particular sealant for the diff? Or anything to avoid!?
My Rallye project thread
Posted 21st May 2014 at 16:22
Just bung the breather, reverse detent hole and diff up and blast away.
Check the diff bearing preload but its usually fine.
Posted 21st May 2014 at 16:32
Do you need to take any material off inside the housing?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 29th May 2014 at 20:02
allanallen
Not for a quaife as far as I know, doesn't do any harm to keep spinning it as you fit it to check for any binding though Wink
Facebook
Posted 29th May 2014 at 21:14
Is Simple enough to do for anyone handy enough with spanners?
Just fit new bearings and seal up?
Or How would you check or set preload as mentioned?
Posted 29th May 2014 at 21:45
russbez
bumping what andy says /
been putting this off and driving car without 3rd gear
Posted 25th Jun 2014 at 10:38
LOL
Posted 25th Jun 2014 at 10:55
russbez
makes for an interesting driving experience at the wknds LOL
by everyones silence i presum its pretty straight forward, chrsid306 also said its simple so ill see how much i can f**k it up in two/three weeks time when i tackle it
Posted 25th Jun 2014 at 11:02
I did same with mine lol, it's the best gear 3rd aswell lol
Posted 25th Jun 2014 at 11:17
If you can change a wheel, you can change a diff.
  • Posted 25th Jun 2014 at 11:21
    russbez
    it was indeed rather easy Shut up
    silicone RTV sealant for sealing the joint, pretty simple... surprisingly
    Posted 25th Jul 2014 at 11:34
