Is there anything we can do to make the "bite point" higher up? Don't have a huge deal of confidence in the brakes at the moment.
Rallye Race Car
| Author | Subject: Long Brake Pedal |
demondriverdan
The brake pedal on the car is quite long making it difficult to heel and toe while racing. We've got 310mm Megane Brembos, Hi-Tech discs and CarboTech XP8 pads. Copper piping throughout as well.Is there anything we can do to make the "bite point" higher up? Don't have a huge deal of confidence in the brakes at the moment. ________________________________________ Rallye Race Car |
jorg
Senior User Location: Wallasey Registered: 10 Jun 2007 Posts: 816 Status: Offline |
what size master cylinder are you running?________________________________________ 306 2.1 S16 Tarmac Rally CarProject thread: http://www.306gti6.com/forum/showthread.php?id=143956 |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
What fluid have you gone with? Bled thoroughly? ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
demondriverdan
Standard MC and Dot 4. Will change to 5.1 if we have to do any work on the brakes to sort the pedal.Bled thoroughly. ________________________________________ Rallye Race Car |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
I changed the standard master cylinder for a bigger one, around 25mm. Made the world of difference to the pedal travel/feel with my AP calipers. |
demondriverdan
Do you have any details on which one you got and the work involved to fit it? ________________________________________ Rallye Race Car |
remove 23.8mm unit, bolt on 25.4mm unit, bleed brakes ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
welshpug! wrote: remove 23.8mm unit, bolt on 25.4mm unit, bleed brakes ![]() Cheers WP, you're the best Which cars did the 25.4mm MC come from? ________________________________________ Rallye Race Car |
trying to remember where they came from, I know Citroen sport have used one, there's some on the PSA vans but I don't know if they fit directly or not, see what Marting comes back with ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
devere
I couldn't find a lot of info when I was looking for a bigger one. Took HOURS of trawling foreign parts sites and stuff to try and find pictures.As it was, i literally had to go by a picture and hope for the best. I managed to get it right though! Its off a VW Transporter of all things! The only difference when it comes to fitting, is that the ports are on the opposite side of the cylinder to the standard one. So i just fitted a couple of little extenders to reach my current pipes. I think i also had to warm the reservoir and mould that out of the way of one of the fittings, but it was just a hot air gun and a push that sorted it. That's just a problem caused by the ports coming out underneath the reservoir rather than the standard position. Fits perfectly onto the servo, exactly the same fitment as the standard on in that respect. |
demondriverdan
Thanks very much! No idea how you found that :pSomething like this should be ok? http://www.vwheritage.com/vw_spares_Master-Cylinder-T4-19603-No-ABS-ITT-Calipers-7D0611019A_act_shop.product_pID_143248615.htm ________________________________________ Rallye Race Car |
devere
Il have a look and see if ive got a part number on mine in a minute. As said though, mine only has 2 ports, like the standard 306 one only has 2 ports also. Saves having to block any up.And whaen I said it took HOURS of searching, that pretty much meant DAYS! The main concern apart from fitting to the servo was the reservoir mounting holes. Where the fluid goes in. A lot of them have a bigger gap there |
devere
This is the one you want.http://www.vwheritage.com/vw_spares_Master-Cylinder-With-ABS-ITT-Calipers-T4-01-96-03-7D0611019B_act_shop.product_pID_143250031.htm Its actually the next one on from what you listed. Just got a B at the end of the number rather than an A! That's the part number that is on the one I use. |
excellent thread, I've always thought my 330s gave me a lot more pedal travel, the things makes me go dizzy it stops so well but I've always thought I seemed to be have to press the pedal pretty hard ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
demondriverdan
I'll get one of those MCs and do a small thread on how to fit it, just for future reference.________________________________________ Rallye Race Car |
buzzbrightyear wrote: excellent thread, I've always thought my 330s gave me a lot more pedal travel, the things makes me go dizzy it stops so well but I've always thought I seemed to be have to press the pedal pretty hard you would have to press harder with a bigger MC, but it wont move quite so far. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Yeah I don't have to press them hard just quite far compared to standard________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Did it need to have the tie wrap around it or is that just a precaution?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
devere
Precautionary. The stuff I do occasionally has unbelievably bouncy and rough tracks in places with hard suspension. Didn't want the chance of it riding up in any way. Even though the pin that goes through should hold it in place regardless. |
demondriverdan
Looks fairly simple to do!________________________________________ Rallye Race Car |
