Author Subject: to borrow 20mm wheel spacers
pugheaven
Does anyone have a pair of spacers that I can borrow for a few days so that I can check that im ordering the correct wherl offset for my new wheels
ill cover delivery costs both ways Thumbs up
Posted 14th May 2014 at 08:17
pugheaven
Passenger ride in the dimma for the helpful member Whistle
Posted 14th May 2014 at 14:55
Ive got some on the race car you can borrow. Edit, I think mine might be 15mm Unsure
Posted 14th May 2014 at 17:07
6waysforward
Ive got some 24's knocking about if that helps?
Posted 14th May 2014 at 17:25
pugheaven
Thanks lads but I need 20mm really as the new wheels are et20, I just want to see if im going to need wider to make them sit nicely with the negstive camber
Posted 14th May 2014 at 18:11
Cjwatson27
Do you just need them for a mock up or are you driving it ? Ive got some very dodgy looking universal ones that came on my white xsi not sure if ive still got the wheel bolts tho
Posted 14th May 2014 at 18:40
pugheaven
Na I wont be driving the car with them fitted, I will need 4 in the end but just want to use them to see how the wheels will sit so then I can let the wheel company know what offset I want, iv currently put the order on hold so the sooner the better really, would really need the bolts but if not ill have to buy some
Posted 14th May 2014 at 19:20
jimmyrallye
I know this sounds a bit Ye ha but I would just use some window/glazeing packers to make 20mm then just gently bolt the wheels on, I've got loads if you need any
Posted 14th May 2014 at 20:27
Puggitt
I've got a full set with bolts and lock nut+studs but I'm over in newzealand so that's a bit of a pain LOL
Posted 14th May 2014 at 20:59
Mine wouldn't be much use as it's converted to studs.
Posted 14th May 2014 at 22:30
rallyestyle
Just make a spacer out of wood, will allow you to do what you need to do Yes
Im assuming you have longer wheebolts already?
Just Drive It
Posted 16th May 2014 at 16:26
