The length is 158mm
small end 22mm
big end measured with the bearing in is 44.5.
Dont know what these fit, was told they were ex touring car when they used a 45mm crank
Open to offers around £100ish
| Author | Subject: peugeot sport conrods |
morgan205
Newbie Location: ystrad meurig Registered: 30 Oct 2012 Posts: 25 Status: Offline |
Here i have some peugeot sport conrods. The length is 158mm small end 22mm big end measured with the bearing in is 44.5. Dont know what these fit, was told they were ex touring car when they used a 45mm crank Open to offers around £100ish |
morgan205
picsmorgan205 has attached the following image: |
morgan205
eddy_gti6
Interested in these if they will fit with the pistons I am getting. Will k ow more in the morning.Im sure standard big end is 53.7 ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
dcc
Senior User Location: Wales Registered: 24 Feb 2009 Posts: 502 Status: Offline |
I can ferry these from mid wales down to south if needed ![]() ________________________________________ 205 GTIXsara HDI |
jammapic
Senior User Location: Manchester Registered: 11 Jun 2010 Posts: 778 Status: Offline |
Be interesting to know what they actually fit.JP ________________________________________ HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech306 GTi-6 Track Car - 200+ hp all N/A! 306 DTurbo Track beasty - 209.9hp - RIP |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
I've got some identical, will fit a 45mm big end steel crank. Can you have a look at the rod bolts and tell me what they say on them? Will be either ARP 2000 or ARP 625+. Let me know what you'll take for them posted to Yorkshire. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
jammapic wrote: Be interesting to know what they actually fit. JP A Longman btcc engine, one of the ones with the £1500 small big end forged steel crank, theyre otherwise nearly identical to standard gti6 rods bar being bushed at the small end as per any aftermarket rods and performance engines. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jammapic
That's a shame... not shelling out £1500 for a crank!________________________________________ HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech306 GTi-6 Track Car - 200+ hp all N/A! 306 DTurbo Track beasty - 209.9hp - RIP |
Could just get your crank ground, not sure what the limit is for the XU10 crank, or offset grind a 92mm crank to make a 2.3 ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
morgan205
Think these would work with a ew10 crank as that's got 45mm big ends but is 88mm stroke so would need some custom pistons maybe? |
morgan205
SOLD |
