Author Subject: Where to source supercharger belt from?
thomo6
Ok so know that the code for the correct belt is JPK1560, but am struggling to find a place to buy from. Apologies if I am been a bit slow but have googled it with no joy.
Any one have any info to help?
Thanks in advance.
Posted 5th May 2014 at 21:53
Rich E Forum Admin
It's 6 PK 1560
http://www.carparts4less.co.uk/search/202110105/p/home
Posted 5th May 2014 at 21:57
Does everyone just use a standard belt or can you buy any form of uprated / stronger one? I've seen several SC kits using a Green belt before and the one that's currently on mine doesn't look like any old off the shelf £8 belt to be honest.
I'm gonna replace it before pugfest as it squeaks slightly when cold sometimes.
Posted 29th May 2014 at 13:16
russbez
iv had a few over the years they all seem to last about 2 years then fall to bits
My Rallye project thread
Posted 29th May 2014 at 13:55
306 or the belt?
  • Posted 29th May 2014 at 14:06
    russbez
    LOL
    if i said just the belt id be lying Yes
    Posted 29th May 2014 at 14:18
    Pete - The green belts are the 8-rib ones, I have one on mine. Yes
    Posted 29th May 2014 at 22:14
    Keep meaning to look at the one that's in mine will do it later. Can't see a standard rubber s**tty alternator belt is gonna last 5 mins....
    Posted 31st May 2014 at 08:08
    They last pretty well, what kills them is when the idler pulley bearings start to fail causing the pulleys themselves to tip putting side load on the belt as this chews them up really quickly. Buy good quality Dayco or Gates belts for the longest life in the first place, and check the tensioner and idler pulleys regularly.
    Posted 31st May 2014 at 09:40
    Niall
    They aren't just 8 rib. The green ones are the Gates Green stripe ones which are designed for supercharger use and they do them in various sizes. Im currently trying to source a 6pk1165 but they aren't easy to get in the uk.
    Posted 31st May 2014 at 09:44
