Author Subject: Engine gasket set
craig903
Hi, I'm trying to gather the required bits to rebuild my engine, currently the crank, pistons and conrods are built up. It still needs crank seals and everything else.
Peugeot list an 'Engine gasket kit/set' part number 0197 w2. I've spoken to my local peugeot dealer and they have never supplied one and cannot tell me what it contains. Does anyone know what exactly it contains?
208 GTI Owner
Posted 25th Apr 2014 at 19:03
mechanical_repairs
Basically it's an engine gasket with every gasket you need. Surprised your dealer has never sold one.
Carl
Posted 25th Apr 2014 at 20:15
craig903
This is probably a dump question since it states 'gasket set', any seals included would you know?
208 GTI Owner
Posted 25th Apr 2014 at 20:23
jord294
Probably the cost of genuine put people off.
My local main dealer reckons I'm the only person that regularly buys axle bits.
scotzman
I'm welcomed by name in my dealer like I'm their best customer and my newest Pug is 17 years oldLOL
Posted 25th Apr 2014 at 20:27
Rich E Forum Admin
Last time I bought one it had the following inside:
2x Camshaft seal
2x Oil pump gasket
2x Crank shaft end cap seal
1x Exhaust manifold gasket
1x Inlet manifold gasket
1x Large crank shaft seal (flywheel end)
1x Small crank shaft seal (cambelt end)
1x Water gallery end cap seal
1x Thermostat housing gasket
1x Thermostat gasket
16x Valve stem seal
1x Crank pulley washer
1x Sump plug washer
1x Thermostat housing bleed screw washer
1x Oil gallery plug washer
1x Mystery small rubber washer
1x Mystery medium copper washer
10x Head bolt washer
1x Tube of assembly paste
Posted 25th Apr 2014 at 20:48
craig903
Rich, thank you for your responce thats exactly what I needed to know. I shall be ordering one off those.
208 GTI Owner
Posted 25th Apr 2014 at 20:51
Interestingly, it seems as if you have to buy the head gasket separately then.
Rather odd, seeing as it's an "engine gasket set" and has all the others included.
Posted 26th Apr 2014 at 08:17
Rich E Forum Admin
No worries. I may actually have a spare one here if you haven't ordered one from Pug yet...
Yeah, it doesn't include the head gasket. It's incase you need a repair size HG and not a standard thickness one.
Posted 27th Apr 2014 at 10:12
Good point Rich, I hadn't thought of that. Thumbs up
Posted 27th Apr 2014 at 10:59
