Author Subject: Xsara Phase1 2.4 rack ...Help please !
Got a Xsara 2.4 rack off 306 Pug on here & I want to refurb both sides inc under Gators linkage ....
Just been told by my local Peugeot dealer I use ...track rod ends are same part no for 6 & VTS Xsara ....
But Rods next to track ends & Linkage inside gator is diff part no also price & picture shows diff visually?
Several people have said they are the same bits & interchangeable ?....it appears no ????
Also does that mean for me to fit it on my 6 I need to order Xsara VTS bits ...I have reg no ????
Will the complete VTS Xsara fit my 6 or do you have to change rod lengths to 6 ones or are they same length ?......
HELP Thumbs up
Posted 25th Apr 2014 at 18:34
jord294
Fit 306 track rod arms, as they are longer (well they were when I fitted them to my last rack)
Track rod ends are the same
Posted 25th Apr 2014 at 19:12
I want to change the linkage inside Gator its worn & falls side to side on its own weight m8 ?
Is A Xsara one diff width from 6 ...if not I'll just order everything new Xsara inside gator to track Rod ends !!!! £43.00 per side ?
According to part nos Xsara & 6 only have Track rod ends as same part nos .!!!!
Everything else diff part nos & looks diff on Pics
The joints inside Gator that wear are diff looking & Part nos to 6 ones !
Yes the track rod ends both part nos the same m8 !!! Unsure
Posted 25th Apr 2014 at 22:02
jord294
Linkage inside the gaitor is the track rod arm. So buy 306 as they will fit to rack.
Gaitors are the same on xsara and 306
Track rod arms and ends are good price from ecp
Posted 25th Apr 2014 at 22:20
Thumbs up big Thankyou again
Posted 25th Apr 2014 at 22:39
As Always Andy ...you are 100% correct 306gti6 ones are 15mm longer each side ...than Xsara mk1 2.4 Rack ...100% same fitment as you had said & bought new Gti6 ones both sides the same part no !!! ...Sat in Main dealer looking at both ....Thumbs up...
P.S ..rubber boots same on both also.!
Your are the Kiddie Andy Big grin
It's costing me a small fortune Whistle
Posted 1st May 2014 at 12:10
