Author Subject: Removing and refitting exhaust cam cover.
Easy? Not easy?
Advice?
I need a new one as the thread for the headshield on mine is donald ducked
Posted 25th Apr 2014 at 11:08
scotzman
Easy..
and I have a pair for sale with good seals Smile
Edit:- just noticed you posted on my thread already
If my notifications worked I would have known alreadyThumbs down
Posted 25th Apr 2014 at 11:22
Anyone know the process for this?
Posted 2nd May 2014 at 10:28
the cam cover just unbolts using the top bolts, and if you don't ruin the seals you'll be fine. just make sure everything is clean like mating surfaces
Posted 2nd May 2014 at 10:40
Cool, Do i need to top it up with some other form of sealant?
And i think i read you do them up to about 8nm leave em for an hour or so and then go up to 10nm?
Try and do them all up evenly as well?
Posted 2nd May 2014 at 10:47
i tend to do stuff in a spiral working outwards but you can't really balls it up unless you're heavy handed and ruin the seals or they don't mate up right. the seals are part of the cam cover underneath so if they're good condition i'd just refit them and see what they're like
Posted 2nd May 2014 at 11:02
A thin bead of RTV sealent is a good shout. I just use it to the centre of the existing seal and then refit. If you've got a steady hand and use a thin bead you won't end up with a mess when you screw it down.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173106_langId_-1_categoryId_255217
  • Posted 2nd May 2014 at 11:16
    Cool cheers both Smile, I'll pick that stuff up tomorrow Dan looks liek its good to have.
    Posted 2nd May 2014 at 11:49
    raunchz
    Just to add, I re-used my covers with oem seal and one leaked slightly. Removed all the oem sealant and put a c.3mm single bead of picture sealant on it, rested back in position for a few hours, finger tightened the bolts and left overnight, torqued them up the next day and it's been spot on so far.
    Posted 5th May 2014 at 06:15
    oldbrownshoe
    raunchz wrote:
    Just to add, I re-used my covers with oem seal and one leaked slightly. Removed all the oem sealant and put a c.3mm single bead of picture sealant on it, .
    What you mean by that ?
    French military victories?
    Did you mean French military defeats?
    Posted 7th May 2014 at 09:54
    Question. How the #### do you remove the bolt in the far left hand corner of the cover, theres a reserviour of some sort directly above it which doesnt seem to give ypu any room to fit a tool in thats sizeable enough
    Posted 11th Jul 2014 at 13:07
