Author Subject: Coolant pipe question
demondriverdan
Quick question, we had to cut this coolant pipe while taking the head off as the clips were destroyed and wouldn't open. On the spare car, it was blanked off and the thermostat didn't have any holes accepting it. What's it for / do I need it?
To the right of the block, near the earth cable you can see the cut pipe:
Rallye Race Car
Posted 14th Apr 2014 at 23:03
Niall
Is that the tiny little one that goes from the metal pipe along the back of the block to the thermostat housing? Iirc its to recirculate water before the thermostat has opened.
Posted 14th Apr 2014 at 23:08
demondriverdan
Yup, that's the one. Annoying thing as there wasn't enough space on it to move clips around so we just cut it off.
If that's its use, probably worth keeping then. Only way you can cap it off is if you don't run a thermostat I guess.
Rallye Race Car
Posted 14th Apr 2014 at 23:10
Niall
Yeah they are a bas**rd. Easiest way to remove it is to remove the bolt holding that end of the pipe to the block and then you will get enough movement to pull that pipe off. I would open the clips with some mulgrips and then release the rubber pipe with a flat head screwdriver (they normally stick to the pipe)
Posted 14th Apr 2014 at 23:20
demondriverdan
Appreciated. Easy enough to do now the head is off, was just a pain with everything in place. Don't happen to know the size? Will order some new pipe to create a new one, no point paying Peugeot for the part!
Rallye Race Car
Posted 14th Apr 2014 at 23:22
plenty of space to move the clips, especially if you slacken the 13mm bolts securing the metal pipe to the back of the block.
pug/citroen only, less than a fiver.
you can't cap it as the heater matrix is fed from that metal pipe due to the exhaust manifold, J4R engines dont have the metal pipe as they have a cast manifold and fed from the rear water takeoff housing and have a single takeoff on the back of the thermostat housing.
nothing to do with the thermostat itself.
Posted 14th Apr 2014 at 23:24
I believe it's 1/2 inch diameter.
Years ago, I used to keep a metre of it and cut small pieces off to size when doing heads. It was such a pain to remove the pipe, was much quicker to cut it and then fit a new length.
For the price though, you may as well buy one from Pug.
Posted 15th Apr 2014 at 07:31
demondriverdan
Thanks guys, appreciated.
Getting the part from pug is a pain as there isn't one near me which I why I was just going to order new pipe and cut it down.
If I were to blank off the heater matrix, I could then cap it? Going to remove it at some point anyway.
Rallye Race Car
Posted 15th Apr 2014 at 09:00
ahh the dealer tech bodges are starting to come through Razz
Posted 15th Apr 2014 at 09:55
use a Citroen dealer, or phone one that is willing to post it to you, I know Ed and Steve at Warners in Tewkesbury are willing to do so.
you can't dispose of the pipe, or the engine will just boil, as for disposing of the matrtix, daft idea.
Posted 15th Apr 2014 at 09:58
demondriverdan
Pipe 5 in the diagram?
Plan is to remove the matrix and fit an electrically heated front windscreen, weight saving and all that.
demondriverdan has attached the following image:
Rallye Race Car
Posted 15th Apr 2014 at 10:53
LOL
I'm sure you've done worse...
Posted 15th Apr 2014 at 23:41
I was no dealer tech...
Posted 15th Apr 2014 at 23:57
