Author Subject: Mounts.
Markie
Im going to replace rear beam mounts and engine mounts as the car's not handling too great, just wondering if anyone has used vibratechnics mounts? If so, are they worth getting? Ive read a lot on here about solid mounts but think that would be too much, thinking about oem mounts but saw the vibra's and thought they might be a nice upgrade without being to harsh.
Car is a daily with some spirited driving now and then.
cheers.
Posted 6th Apr 2014 at 16:54
jord294
O/e for top engine and gearbox mount, and vibra for bottom engine mount.
Ideal to shim the buffers on top engine mount aswell.
As for rear, don't buy cheap!!
I have genuine Peugeot here and solids
Posted 6th Apr 2014 at 17:00
Markie
Thanks Thumbs up yeah ive been reading about chocking the top mount, mine looks really rusty, hope its not cracked underneath Wink might go with vibra's for the rear then.
Posted 6th Apr 2014 at 17:13
Markie
Is the bottom mount the one that gives the most vibration?
Posted 6th Apr 2014 at 17:31
Yes, don't go solid on that if it's a road car
Posted 6th Apr 2014 at 23:57
aaron6
I have to say, welding chocks in is a good shout. Don't affect the vibration but cuts the movement of the mounts down enough to cut down on the fatigue of the mounts cradle
Posted 7th Apr 2014 at 07:08
pugheaven
Bit off topic but iv got solid mounts all round for the Dimma and im starting to think its just going to cause premature cracking of the top mount structure, can anyone else reassure me that they will be fine as they also have solids all round
Posted 7th Apr 2014 at 15:30
aaron6
Probably not. I had to weld up and patch loads of cracks in stillys rallye. The usual top mount, but rather unusually also the gearbox side chassis leg. I'll see if I can find pictures. But all of this was definitely caused by too solid mounts.
Posted 7th Apr 2014 at 20:46
aaron6
Heres the top mount before and after. I however dont seem to have a before picture of the other mount before repair. Just one from once id fixed it. Smile
Posted 7th Apr 2014 at 20:55
Markie
Could you bolt a chock in? Or use some sealant like tiger seal ir something?
Also, What are the vibratechnics fast road mounts like? Anyone had any experience with them?
Posted 8th Apr 2014 at 08:08
aaron6
If you use a bolt in chock it has to sit under tye mounts bridge. This creates a gap whuch allows vertical movement.
Posted 8th Apr 2014 at 07:08
pugheaven
My solid top mount is held in with a bolt and does not have the standard top nut with a rubber buffer that sits up against the cradle so I was thinking about making a brace that goes across the top mount structure to hold the top of the mont in the middle if that makes sence.
I was also thinking about buying a couple of those engine torque dampers to add extra bracing to the engine and chassis
Posted 8th Apr 2014 at 17:20
oh dear, god help you if one of those caged nuts get damaged LOL
Posted 8th Apr 2014 at 17:55
No problem, big drill, big riv-nut.
Posted 8th Apr 2014 at 18:25
aaron6
They aint caged anymore. Wink welded ftw!
Reasonable repairs I thought. Wanted it to be over kill really as the rallye got boosted and was getting the solid mounts again and wouldn't get an easy life.
Posted 8th Apr 2014 at 19:28
