Author Subject: little pipe sucking air into engine
calumsaddler
I was wondering what the little plastic pipe that sucks air into the engine is called.
it is located just behind the holder for the accelerater cable, near the starter motor
When I cover it with my finger it cuts the engine out. I put a little vent filter on it cause I thought if its sucking in air I need some kind of filter on it.
but can someone please tell me what its called and what it does cheers.
sorry if it doesnt make sense or spelling
good to go!!
Posted 1st Apr 2014 at 19:55
daver6
Idle control (valve)?
Wishbone Polybushes available
calumsaddler
Sweet cheers mate I had one of them little air filters on but its come off guessing thats the cause of my un-natural revs on ticks over Im guessing?
good to go!!
Posted 1st Apr 2014 at 20:01
daver6
Possibly, but check for other air leaks and possibly clean the throttle body and idle control valve out as they're known to cause problems
Posted 1st Apr 2014 at 20:22
RetroPug
Possibly, either that or the ICV is going dodgy.
If you've run it without a filter for a while the ICV might just be really dirty in which case you should try cleaning it first. There is a guide in the FAQ section.
Posted 1st Apr 2014 at 20:24
calumsaddler
Cheers ill give it a clean after work. is brake cleaner best for doing it ?
good to go!!
Posted 2nd Apr 2014 at 08:29
RetroPug
That'll work but avoid spraying it right down inside it, and re-soften the o-rings with WD40 or something.
Posted 2nd Apr 2014 at 18:04
calumsaddler
Will do cheers guys
good to go!!
Posted 2nd Apr 2014 at 20:33
jamiek_uk2000
bumpage, what size filter does this need? ID of 19mm rings a bell
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 15th Apr 2014 at 21:43
