Author Subject: Diff housing bolt torque?
Please could somebody tell me what torque the bolts need to be that hold the diff casing on?
I've tried searching the forum and googling to no avail.
Cheers. Smile
Posted 24th Mar 2014 at 18:46
jeffers Forum Admin
Pinched from 205 drivers,
Its also in the haynes manual, chapter 6 transmission;
Crownwheel securing bolts; 65Nm / 48lbft.
chipstick, on 07 Jan 2013 - 10:23 PM, said:
Talking of torque. When refitting the diff housing, what torque should the 11 and 16mm bolts be done to, and the 3 speedo drive housing ones? Haynes lists various torques but none of those. When it comes to sealing, I didn't notice any sealent upon removal. Is that correct? If not, what should be used?
Also in haynes chapter 6;
Final drive half housing bolts, M10; 41Nm 30lbft
Final drive half housing bolts, M7; 12Nm 9lbft.
Speedometer pinion adaptor; 12Nm 9lbft
Final drive extention housing bolts ; 15nm 11lbft
Sealant shouldn't really be needed but I tend to put a thin bead of rtv on the mating faces.
Hope this answers your question Steve! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 24th Mar 2014 at 19:44
Thanks Lee, i didn't think my haynes manual would have the info in it so didnt take a look. Doh
Posted 24th Mar 2014 at 21:15
luke306rallye
This is just what I needed also.
Thanks Smile
Posted 24th Mar 2014 at 22:19
Next question: Are you meant to tap the bearing race up against the tapered rollers with a little force on the m10 bolts to create a bit of preload?
I had the crap idea of fitting my new 'box with the diff and housing removed then fitted them once the box was in place, what a bugger of a job that was! Now I've got some side to side play in the diff and wondering the best way to set it up right, I'll be gutted if I wreck this new box through my own stupidity. Doh
Posted 30th Mar 2014 at 20:25
have you fitted the speedo drive housing yet?
Posted 30th Mar 2014 at 21:24
No not yet, I'm assuming I should slacken of the diff housing bolts slightly then fit that to press it in the correct amount?
I looked in the Haynes manual and couldn't find anything about the diff.
Posted 30th Mar 2014 at 21:33
no need to do that, just bolt it on, that's what holds the diff bearing in and sets the preload on it.
Posted 30th Mar 2014 at 21:48
Awesome, thanks for that Mei. Thumbs up
Posted 30th Mar 2014 at 22:09
