Author Subject: Citroen Xsara Vts Phase 2 Breaking
alastairh
 Citroen Xsara VTS Phase 2 Breaking. 2002 Phase 2 in Silver. Covered 100,000 miles.I
I bought this to donor the engine 6 weeks ago, but the sale of the 205 I was to convert fell through. Since buying the car it has been in daily use by my brother who clocked up 1500 miles without issue. This car will be stripped and gone on Saturday 29th March.
Engine, XU10J4RS GTi6 engine.Solid engine, doesn't smoke, over heat, tap etc. Engine looks clean and honest. Pulls and drives very well. Package includes, both manifolds, wiring loom and multiplex ECU, PAS pump, alternator. To convert this into a 205, you will need a few other odd bits, (Earlier 306 / Xsara ECU and wiring loom, engine mount arm*, 3 pin knock sensor*,) plus other standard conversion parts. Still fitted in the car if you want a video. £350 collected. I can ship for cost, but just ask.* I have these bits if you need them.
Gearbox BE3/4 Xsara VTS 5 speed. Once again, solid gearbox with no crunching or whining. £80 collected or £105 shipped within the UK.
GTI6 283mm Front brake setupPair of callipers, including yokes and bolts. Discs and pads were both replaced less than 3 months ago and stop very well without any vibrations etc. £75 collected or £85 posted.
2.6 turn quick PAS steering rack setup with pipes and reservoir
Well known bolt on upgrade for 205 owners which will need minor mods to fit (Use the search for answers). Includes Rack, Lower xsara UJ, All PAS pipes and reservoir. £110 collected or £120 posted.I have another 2.6 quick rack but without the pipe work that I would sell for £90 collected or £100 posted.
Xsara VTS Trailing arms with disc hubs and brackets
Trailing arms shafts removed. Includes disc abs hubs, calliper brackets. Ideal upgrade / easy disc conversion. £40 collected or £50 Posted.
21mm Torsion bars
Well known upgrade for 306 GTi6 owners and will not fit a 205/309 beam. £80 collected or £90 posted.
Located in Kettering Northants. For any more parts, just ask.
ThanksAl
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 23rd Mar 2014 at 20:59
burnout21
Do you still have the shell/doors?
Posted 24th Mar 2014 at 12:41
woody.
Have you got the knock sensor, if so, how much?
Posted 24th Mar 2014 at 13:27
alastairh
Hello
Yes the shell and doors are still with me.
Which type knock sensor do you need, 2 or 3 pin?
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 24th Mar 2014 at 13:59
burnout21
How much for the drivers door loom posted please.
Posted 24th Mar 2014 at 15:18
woody.
Not a clue what knock sensor, my 6 is a 99plate and most parts are phase 3 I think. Didn't know there was more than one connector Dunno
Posted 25th Mar 2014 at 22:53
Do you have any of the sensors off the thermostat housing?
If so, how much? I could pop over and collect at some point.
Thanks
Posted 26th Mar 2014 at 08:54
alastairh
£15 posted.
It should be a 3 pin, let me check my spares.
CJM - Possibly, i have someone after the engine so i will ask if they need them / have a look in my spares box.
Al
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 26th Mar 2014 at 09:04
burnout21
Think phase 2 and phase 1 xsara looms are different. Think there is wire for sensing the door open which broke meqning couldnt lock car.
If you could check how many wires or show a picture, i will have it if the same.
Cheers.
Posted 26th Mar 2014 at 10:25
