displaying posts 1 to 25 of 36
Author Subject: 306 BTCC style inlet manifold
As per title, modified inlet manifold.
£120 delivered.
Posted 12th Mar 2014 at 09:19
Is that standard outside ie take all sensors etc bud ?
Posted 12th Mar 2014 at 09:29
yup.
Posted 12th Mar 2014 at 09:36
Looks like standard inlet then ? might be interested
Posted 12th Mar 2014 at 10:33
yes, very well finished, can barely tell it's been meddled with.
Posted 12th Mar 2014 at 10:41
ryangti6
I could be interested in this if its a proper one but guessing from the title 'btcc style', the price and the pics It's not actually one from the touring cars but a home made job?
Ryan
Posted 12th Mar 2014 at 10:43
I doubt anyone would notice the difference on the bum dyno.
Posted 12th Mar 2014 at 13:19
bump.
Posted 28th Mar 2014 at 21:55
eddy_gti6
Is there actually buch difference between this and a proper BTCC inlet?
Quite tempting this then sell my VLR inlets Hmm
Posted 28th Mar 2014 at 23:49
Probably only that you can use the standard management which you couldnt with the proper ones.
Posted 29th Mar 2014 at 05:52
eddy_gti6
Makes no odds to me, I will be running an omex 600. Doesnt the btcc ones have the map hole blanked off and run a 70mm TB?
Posted 29th Mar 2014 at 11:37
something like that yeah.
Posted 29th Mar 2014 at 11:46
eddy_gti6
Let me have a think. All I need for the VLR is a fuel rail and TB adapter and maybe to move my alternator too.
Posted 29th Mar 2014 at 12:25
so many say they're interested but don't come up with the goods!
Posted 3rd Apr 2014 at 11:47
doof
That's interest for you. I'm interested. Not going to buy it but i'm interested.
Posted 3rd Apr 2014 at 12:56
eddy_gti6
I am also interested but only need a fuel rail and throttle body adaptee for my VLR so no point giving up now. GLWTS Thumbs up
Posted 3rd Apr 2014 at 21:20
Cjwatson27
Could I just swap all the parts from the orginal setup on to this ? Would that work or does it need a stand alone ecu to get the most from it ?
Posted 3rd Apr 2014 at 21:55
eddy_gti6
Mapping would see the best from this but would run on standard setup fine. Cant remember who it was but someone has tried and tested it
Posted 3rd Apr 2014 at 21:57
Cjwatson27
Yeah read a bit about them but they said you need stand alone but they did have modified throttle body, just looking for something for my new engine has i don't want to go down the cam route again.
Posted 3rd Apr 2014 at 22:01
RussianGuy?
Posted 4th Apr 2014 at 00:57
eddy_gti6
Daveyboy I think?
Posted 4th Apr 2014 at 01:42
Yeah it was me, big power loss if you just bolt one of these to an otherwise standard engine, it needs to be fitted as part of a raft of other modifications, pocketed or forged pistons, hotter cams, remap etc etc. that never happened on mine so I took it back off and sold it. You loose 15-20 ft/lbs of torque midrange then power increases at top of the rev range but overall on a standard car the BTCC inlet will make you slower. It will fly if you do the other mods too though, I think estimates were around the 220-230 bhp mark with hot cams and decent pistons/rods allowing some higher rpm.
Posted 5th Apr 2014 at 16:25
walker_texasranger
What do you class as hot cams? PT82's or similar?
Hilux InvincibleX daily
306 No.13 Doh
Posted 5th Apr 2014 at 17:37
Yeah I guess so, if you're going to the trouble of doing the bottom end work to allow 8k, and high valve lift/long duration then it makes no sense to hold back on the cams.
Posted 5th Apr 2014 at 17:42
bump.
before I chop it up and make a throttle body inlet Razz
Posted 20th Apr 2014 at 13:56
