Author Subject: Gears 'Sticky' Coming Out of 2, 4 & 6
Fellows
I find that when cold, moving out of 2nd, 3rd and 4th (and reverse) can require a little bit of a push and gives a bit of a squeak.
It goes into every gear fine, and when nice and warm is fine. Its just when cold that the problem occurs. I have installed the upgraded miles linkages but it has not helped this particular issue (everything else about the gear change is much better though).
I have read that shortening the long linkage helps get it into these gears. Is it likely to help getting out of them?
Thanks
Posted 12th Mar 2014 at 07:40
daver6
Tried new fluid?
Wishbone Polybushes available
Posted 12th Mar 2014 at 07:42
Fellows
It's had new gearbox oil about 1000 miles ago, so it shouldn't be that.
Posted 12th Mar 2014 at 09:33
it could be if it was the wrong stuff.
Posted 12th Mar 2014 at 09:37
allanallen
What grade oil?
If it's affected by temperature it's pointing towards an oil issue, some boxes can be a bit clunky when cold mind.
Worn or bent selectors also make it difficult to get out of gear
Facebook
Posted 12th Mar 2014 at 09:40
Fellows
I forget exactly what oil it was. I will check when I get home.
It is the Castrol gearbox oil supposed to be designed for notchy gearboxes. I gave it a go as it worked wonders on my TVR's gearbox. Possible that it was a mistake then.
Posted 12th Mar 2014 at 10:04
scotzman
Best sticking to the genuine Pug stuff.
Posted 12th Mar 2014 at 10:55
allanallen
There's no specific need for peugeot oil just make sure it's the correct grade, 75w80
Facebook
Posted 12th Mar 2014 at 11:54
jimmyrallye
Could be clutch on its way out
Posted 12th Mar 2014 at 12:29
Fellows
Brand new clutch, so I hope not! Happily its warrantied...
I will double check the oil grade, and if its wrong, I shall perform a quick swap.
Posted 12th Mar 2014 at 12:44
darkgti6
ive tried pug oil and other brands in the box. the pug oil was the best by far imo.
Team Peugeot Sport 308 Gti�
Posted 12th Mar 2014 at 20:21
Agreed, for some reason other brand 75w80 oils just don't seem to perform nearly as well. No
Posted 13th Mar 2014 at 20:41
Redline MTF worked pretty well in my MA 'box, although I'm trying something now which is much better cold that either of them, but I ain't recommending it until I've got a few k's on it to check for wear and get a UOA done on it.
Posted 19th Mar 2014 at 17:04
Fellows
Small update, and check to see if anyone else can help.
I tried an oil swap to the correct Peugeot gearbox oil, and sadly it has just made the problem worse - which is annoying as I didn't think to save the Castrol stuff. Complete waste of money!
Is there anything else that I can try, otherwise I'll just put the Castrol Syntrans 75w-90 back in I think. It's been the best so far.
Posted 26th Apr 2014 at 11:08
