Author Subject: Gaz coilovers top adjuster is loose
Marcdimma
Hi I have a little issue with my gaz coilovers on my dimma
The top adjustable knob on my front shockers as come loose so I carnt loosen it too adjust the dampness
I small spot weld on the top would fix it for sure but I'm not too shore on welding on shockers
Is it safe too weld
Posted 10th Mar 2014 at 23:07
pugheaven
Lets see a pic of your dimma!
Posted 12th Mar 2014 at 14:29
Err, that little knob is part of a shaft that runs all the way down the inside of the damper - if it's 'come loose' then it's broken...
Posted 19th Mar 2014 at 16:59
Yup! Sad
I snapped the top off my KW damper and found out it goes all the way through the body, to the valve at the bottom of the strut. Rebuild time!
Posted 19th Mar 2014 at 17:04
Marcdimma
The knob in question threads off when u twist it.
It was tack welded before but I filed it down too stop it from denting the underside ov my bonnet
I've only just got the same shocker back from gaz
It was leaking oil from the top. The shockers have probably only covered 200 miles from new
Starting too think these gaz shocks are w## k
Posted 19th Mar 2014 at 23:59
Have you got a picture, because something doesn't sound right there.
Posted 20th Mar 2014 at 00:35
mabgti
NV motors
Gaz.. Nuff said
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Mar 2014 at 09:57
Marcdimma
I'll get a pic tomorrow I'm back in garage ripping me gti6 bk out (knackerd rings)
The bar that runs down the shaft is still in tackt just a little knob off the top the winds off
Posted 22nd Mar 2014 at 23:33
