The car is being mapped on friday and I've suddenly realised i haven't even considered what fuel to have it mapped on. Suggestions?
I suspect i will get a little more power from 97/98 but 95 is cheaper and more widely available.
Author | Subject: 95 or 97 ron? |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
Guys,The car is being mapped on friday and I've suddenly realised i haven't even considered what fuel to have it mapped on. Suggestions? I suspect i will get a little more power from 97/98 but 95 is cheaper and more widely available. |
Posted 4th Mar 2014 at 23:05
stan_306gti6
Forum Admin Location: Kent Registered: 18 Jan 2004 Posts: 21,768 Status: Offline |
V-Power for best results. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Posted 4th Mar 2014 at 23:14
Get it mapped for 2-stroke, it'll rev higher and you'll get significantly far more power per litre. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Posted 5th Mar 2014 at 10:03
aka JKshooter Location: Taunton, Somerset Registered: 15 Jun 2006 Posts: 10,305 Status: Offline |
Get it mapped on what you intend to use going forwards would be my suggestion.________________________________________ |
Posted 5th Mar 2014 at 10:05
rikky
🦔 Location: cheshire Registered: 28 Feb 2004 Posts: 26,796 Status: Offline |
owain wrote: Get it mapped for 2-stroke, it'll rev higher and you'll get significantly far more power per litre. ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Posted 5th Mar 2014 at 10:25
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
As (I think) dan says, get it mapped on wherever you'll be mainly filling up, no point mapping on v-power if youve gotta travel 20 miles to fill up! I had mine very conservatively (ignition timing) mapped on 97, when I'm stuck I can fill up with 95 and it still runs nice. ________________________________________ www.bridgecraftmotorsport.co.uk |
Posted 5th Mar 2014 at 10:30
I your running boost through a high compression engine not designed for it ten if go with Vpower personally and make sure you've uprated the heat range on the spark plugs to 7's. I know your not aiming for lynx kit figures but still think I you don't it may knock particularly on 95 so if be using nothing but Vpower in it personally. ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 6th Mar 2014 at 22:08
allanallen
armzs16 wrote: I your running boost through a high compression engine not designed for it ten if go with Vpower personally and make sure you've uprated the heat range on the spark plugs to 7's. I know your not aiming for lynx kit figures but still think I you don't it may knock particularly on 95 so if be using nothing but Vpower in it personally. If he puts v power in it the mapper will no doubt add more ignition advance, If then Niall gets stuck and can only put 95 or 97 in, it may knock. Better to get mapped safely on something that's readily available. Nialls car has the potential to make the same power as a lynx low boost kit. ________________________________________ www.bridgecraftmotorsport.co.uk |
Posted 7th Mar 2014 at 09:02
doof
Regular Location: nottingham Registered: 24 Nov 2007 Posts: 231 Status: Offline |
On a supercharged car mapped with 97 you can probably get away with 95 as it's barely boosting low down in the rev range. Obviously high loads are lower rpms are bad but I've filled up with 95 before when 97 wasn't available. |
Posted 7th Mar 2014 at 09:24
allanallen
doof wrote: On a supercharged car mapped with 97 you can probably get away with 95 as it's barely boosting low down in the rev range. Obviously high loads are lower rpms are bad but I've filled up with 95 before when 97 wasn't available. Nialls car will have 7psi+ from tickover ________________________________________ www.bridgecraftmotorsport.co.uk |
Posted 7th Mar 2014 at 10:14
doof
Posted 7th Mar 2014 at 10:18
mine makes 9psi top end under full load (low boost) but his charger is completely different. As the cars had no engine in fr ages it clearly isnt his daily so why does it matter if its mapped on 97 or vpower? never that much distance between shell garages. Ive never put anything below 97 in mine and wouldnt be driving the car somewhere with no juice in i dont think its difficult. 99% of the time its always got vpower occasionally ive had to settle for bp's 97. but as said if you cant be arsed doing that mot of the time and just wanna run it on 95 most kf the time then get it mapped on that. ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 7th Mar 2014 at 13:45
