| Author | Subject: Lower rear shock bolt welded in |
tony1991
Regular Location: northampton Registered: 07 Nov 2008 Posts: 406 Status: Offline |
So I'm trying to change my shocks got one side of fine. The other was been a pain so sprayed it with penetrating fluid last night just came back to it hitting it with a sledge not budging so after a little clean around. It looks like it welded in. Can't think why other than a bodge. Any one any ideas of removing it |
hit it harder.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
3rd time lucky
Seasoned Pro Location: maidstone Registered: 23 Apr 2007 Posts: 1,879 Status: Offline |
Grind the weld off and replace the bolt?________________________________________ DIABLO GTI-6 - Legend - NILE GTI-6 - SoldCHERRY GTI-6 P1 SUPERCHARGED - Broken up BLACK RALLYE - Sold 205 Dturbo xud9 work horse - Dead CHERRY RALLYE - new toy |
tony1991
Yer I fort that. But it's the fuel tank side so prob not the best area to have a load of sparks. Should be okay tho. I'm drilling the weld of slowly as we speak think it is working |
aaron6
If you want to use a grinder and are worried, wet a bit towel and cover your concern areas. Tbh it'll be fine. I got all round there with a mig welder and had no issues. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
aaron6
Or cut the bolt down and drill it out if you can fit a drill in. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
If you can get to the weld with a hacksaw, you'd be through it in seconds________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
I wonder why it's been welded, maybe there's a reason they felt the need to bodge it to stop it coming undone?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
tony1991
Mm may be but I can't see why as those nuts are the ones with the plastic on the end to stop it coming lose ( I can't remember what they are called). I have another beam here if I have problems with it. I'm not too impressed I have found it is missing the bolts that attach anti roll bar to the plates on either end. Which I'm pretty sure they are needed The bolt I was having issues with I think I few taps with the sledge it should come out now I have got rid of most the weld |
gretsch-drummer
Regular Location: Leeds Registered: 12 Feb 2011 Posts: 276 Status: Offline |
You don't need to remove the bolt though. Just remove the top bolt, compress the damper so you can push it through the mounting arm gap and just pull it off the bolt.....________________________________________ Ph1 Cossack 6' |
Nylock |
It was me I welded it as I didn't have the right size spanner ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
mcvite
Regular Location: basingstoke Registered: 23 May 2012 Posts: 303 Status: Offline |
bigbadbowen wrote: Nylock *Nyloc ________________________________________ ![]() |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
The anti roll bar doesn't have bolts that attach it to the end plates, they're press/knocked on and originally have an Allen head plastic screw fitted to keep the s**t out. There's absolutly no reason whatsoever that the bolt should of been welded in! I'm guessing it's around the bolt head? They sit semi captive in the arm and can be very stubborn, sure it's not just a build up of rust and crap? ________________________________________ www.bridgecraftmotorsport.co.uk |
allanallen
dangti6 wrote: bigbadbowen wrote: Nylock *Nyloc Plastic holder on'er thingy ________________________________________ www.bridgecraftmotorsport.co.uk |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
I assumed he was referring to the 13mm bolt that holds the arb end plates to the trailing arm |
oldbrownshoe
Seasoned Pro Location: Holon Israel Registered: 08 Aug 2008 Posts: 1,795 Status: Offline |
Drill outhttp://www.youtube.com/watch?v=ZhYRMeNdgbU http://www.youtube.com/watch?v=rlebZNXxcXU ________________________________________ French military victories?Did you mean French military defeats? |
tony1991
Yes it was the plastic cap to keep the crap out. Still finding my way around the car so sound abit stupid sometimes. It was welded around the head I managed to drill all the weld off but the bolt was so tight I eventually got it out |
stan_306gti6
aaron6 wrote: Tbh it'll be fine. I got all round there with a mig welder and had no issues. There is your culprit Tony - he's even admitted it. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
