Author Subject: Rich w under car swirl pot and Bosch044 pump
superchargedblack1997gti6
Included is the full setup in call hoses and wiring to front of car? Say £150 plus postage OnoThumbs up
Will put pics up later on
Posted 3rd Mar 2014 at 10:57
tom_g205
Im interested in this set up. Would this set up be fine on a 205 gti?? Im building a 220-230bhp gti-6 track car, and i assume im going to start running into fuel issues soon if i stay on the standard fuel pump.
Cheers Tom
205 GTi-6 every day motor
205 GTi-6 weekend/track car - project 230 N/A fingers crossed.
Posted 3rd Mar 2014 at 11:47
I'd like for you to buy it but I don't think you really need unless you plan on doing some track work? Yes would fit on a 205 without any issues?
Posted 3rd Mar 2014 at 11:50
tom_g205
It is going to be fitted to my track car, i think i may of had some fuel issues in the past when cornering to but i never nailed it down to that being the fault. Any pics available??
Posted 3rd Mar 2014 at 12:00
rallyeash
you'll get starve on a 205 with a decent power 16V engine. especially under half a tank, the damage can also be more than just a bit of cutting out around a bend.
Lots of revs, air and sudden lack of fuel going in isn't ideal on an engine that's cost a few K
309 3dr K20 Type R
Posted 3rd Mar 2014 at 12:12
I will get some pics later when I pop home. I would imagine you did have some issues if you let you're tank get below 1/3rd of a tank. I know I did in my phase 1 gti6
tom_g205
Do you think its a worth while buy ash?? Im thinking it is as i have a reasonably well set up 205 and i dont want to break my new Engine when its done :-)
Posted 3rd Mar 2014 at 12:15
I will take this if its still for sale?
I think I even asked you about it months ago and forgot Laugh
Posted 3rd Mar 2014 at 12:24
Sold
Posted 3rd Mar 2014 at 12:48
rallyeash
yes but appears to be sold!
my only negative thought with this swirl pot is that it has push on fittings that you need to jubilee clip on. Now not really an issue but when fitting a bosch pump, inline high flow filter etc which are all screw in -6 or -8 fittings then to have a swirl pot which has to use normal slide on pipe and jubilee clip fittings seems a bit daft to me?!
Id rather have all -6 or -8 screw in fittings on the whole system rather than a mix of both...?
309 3dr K20 Type R
Posted 3rd Mar 2014 at 13:00
tom_g205
Yes it was sold 2 minutes before I said I would take it. Owell I can look into them properly now and see what I want. I want an under boot floor set up though really. What swirl pot have you got??
Posted 3rd Mar 2014 at 15:47
rallyeash
I don't know what my swirl pot is but its a 1 litre item with -6 fittings on. should be some info on my project thread
309 3dr K20 Type R
Posted 3rd Mar 2014 at 16:03
tom_g205
Ok cheers mate.
Posted 3rd Mar 2014 at 16:06
That's what I don't like about it, it looks like a wonderful professional piece of work but then spoilt with the jubilee clips, I wonder if it could be modified to take the proper screw fittings without making it look like a bodge
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Mar 2014 at 20:31
rallyeash
I don't see why you would want to go to the effort. Just buy a -6 fitting swirl pot.
309 3dr K20 Type R
Posted 3rd Mar 2014 at 20:33
Weld on fittings from earls job done?
Posted 3rd Mar 2014 at 20:47
