Author Subject: spoox silicon
pugheaven
Has anyone used spoox silicon breather hose set? Would be good if you can show pictures of them fitted if possible
Posted 25th Feb 2014 at 11:31
Hawkesfire
make your own from Ash silicone hoses there cheap as chips....
marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 25th Feb 2014 at 13:40
osm2121
Is there any way to bend those hoses? I mean, get the same shape, or curves as the original? By heating and stretching them, or soemthing like that?
Posted 26th Feb 2014 at 12:16
Hawkesfire
No but you can just buy what bends you need or if its only small bore pipe it will bend naturally what hoses are you trying to change?
Marty
Posted 26th Feb 2014 at 12:40
demondriverdan
Would it be possible to buy the pipe and create my own system to replace the cooling pipes?
Rallye Race Car
Posted 26th Feb 2014 at 12:59
pugheaven
I dont want loads of joins so making my own from loads of other bits is out the question, regarding water pipes im thinking about getting alloy rigid pipes bent and then just using silicon joiners as this would also help cool the water down, only down side is that it would raise the engine bay temp slightly
Posted 26th Feb 2014 at 14:51
osm2121
I want to change the gçbreeder pipe that goes to the bottom of the engine. thing is theres so many space to fit it, it has to be almost exactly as the original, right?
Posted 27th Feb 2014 at 11:00
