Author Subject: Piston Rings - Goetze
shah_gti6
Am thinking on changing my piston rings given the engine is in bits after a small incident involving a puddle...
Searched through the forum and came across Goetze rings being mentioned as good quality (cheaper) replacements to the original Peugeot ones...any thoughts? Dunno
The ones available are listed for Vauxhall Red-Top engines but understand this is the same as the XU10J4RS engine
Goetze Piston Rings
Thanks in advance Thumbs up
Nile Blue 306 GTI-6 (2000V)
Posted 25th Feb 2014 at 10:15
jeffers Forum Admin
I've used these on my rebuilt track engine. The engine is yet to run in anger but they were recommended to me by Rich E who I believed has used them without problem in his engine. Either way I know goetz are a decent quality make and the vauxhall ones I used are the same dimensions as the pug items, personally I'd just use them! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 25th Feb 2014 at 11:00
cully
cant remember the name on the box of the ones i fitted
but i did have a choice of sizes
so couldnt order till i removed the pistons to measure the ring width
options were
1.5/1.5/3.0 £64.95
1.5/1.75/3.0 £55.00
and they turned out to be the dearer ones
blue and white box if i remember
Posted 25th Feb 2014 at 11:49
shah_gti6
Thanks guys for the advice - will go for them!! Smile
Posted 25th Feb 2014 at 14:42
bas_306gti
I also used these on my engine, much cheaper.
The oil scraper ring is of a different design then the original one (two rings and a expander instead of one ring) but they fit very well.
Use good piston ring pliers because these rings break very easily.
Posted 27th Feb 2014 at 18:39
