displaying posts 76 to 100 of 176
Pages (8): first .. 3 [4] 5 .. last
Author Subject: Strut not sitting in hub properly?
daver6
Post #76
DOOOF?!
Wishbone Polybushes available
Posted 13th Jun 2014 at 22:59
daver6
Post #77
bump
Posted 28th Jul 2014 at 22:29
gilesy
Post #78
I found this thread by accident, I've had my suspension apart trying to find a massive clunk from both sides and I'm pretty sure this must be the problem I have with mine. Virtually everything is brand new and I have Bilstein B8s
Posted 25th Oct 2014 at 18:37
daver6
Post #79
I also have a massive clunk.
Do your B8's sit above the bottom of the clamp?
Posted 25th Oct 2014 at 21:54
Niall
Post #80
Ive also got an random clunk when i pull away or brake hard with my B8s
Posted 25th Oct 2014 at 22:41
gilesy
Post #81
Proper massive clunks from both sides. Going to get underneath the thing tomorrow and check
Posted 26th Oct 2014 at 01:25
jon boy
Post #82
Did anyone come to any conclusions with this?
Are the B8s too short also?
Any advice would be appreciated as I want to buy some B8s soon Smile
Posted 6th Nov 2014 at 12:57
luke89
Post #83
Bloody hell I have this issue too. The car is now 2 inches higher than it was and the strut really doesn't feel secure in the hub.It sits around 15mm above the bottom of the hub.
Posted 8th Dec 2014 at 17:44
daver6
Post #84
Scary, isn't it? Apparently Bilstein don't care either
Posted 8th Dec 2014 at 17:46
Post #85
15mm sounds more like its not located properly but it wont lift it by 2".
Posted 8th Dec 2014 at 17:48
daver6
Post #86
thing is, they are... well, mine are located correctly.. but still sit like that
Posted 8th Dec 2014 at 17:52
Post #87
I fitted b8s aged ago had no issue cat sits fantastic
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 8th Dec 2014 at 18:05
luke89
Post #88
I think 15mm is enough to raise the car at least 30mm.I'm going to measure my struts and see what the difference is.
daver6
Post #89
Yes, if you still have standards there? This would be great
Posted 8th Dec 2014 at 18:33
luke89
Post #90
The plot thickens. The measurements from the locator lip to the spring seat are actually the same as the standard units.It still doesn't sit in the hub properly though.
Posted 9th Dec 2014 at 13:39
daver6
Post #91
yeah, so the length of the shock is wrong. It should be longer, so that the clamp actually clamps it, rather than nipping the end
Posted 12th Dec 2014 at 23:36
luke89
Post #92
Yep true, however it wouldn't alter the height of the car which is currently my biggest issue.
Posted 13th Dec 2014 at 01:49
daver6
Post #93
No, you're right. I thought the locator tab was wrong, but I'm not prepared to go grinding my shocks
Posted 13th Dec 2014 at 08:47
MisterGTR
Post #94
Just a random thought. I'm not an engineer so forgive me if this seems stupid.
Could it be that the shocks or springs are too stiff/highly rated. Ie can you bounce the front end of the car by hand? What I mean is are they the wrong part and designed for more weight over the front?
Sorry if that's a ridiculous suggestion.
Posted 13th Dec 2014 at 11:26
luke89
Post #95
Not a ridiculous question mate. If you for say the hdi springs I believe the car would sit lower as the hdi engine isn't as heavy so the spring rates will represent that. However my springs and shocks are both gti parts.
Posted 13th Dec 2014 at 12:11
steve h gti-6
Post #96
Have you got the shocks mixed up left/right etc as the small locator tabs are offset to each other depending if they are the left or right one. IIRC they should face slightly towards the front of the car...i could be completely wrong sorry but im sure if the tabs arnt in it dosnt sit right.
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 14th Dec 2014 at 06:50
Niall
Post #97
Its more a case of the shock not sitting far enough into the hub so you would have the same issue regardless of which way around they are.
The only cure for this really is for Bilstein to replace them with correct length shocks!
Posted 14th Dec 2014 at 10:08
allanallen
Post #98
I'm struggling to follow what's going on here, are you saying your dampers measure 45mm from the locating lug/seat to the end of the damper? Or is it 30mm?
Facebook
Posted 14th Dec 2014 at 11:45
daver6
Post #99
If it's to be believed that the B4's actually sit higher than standard shocks, then the ride height issue won't be solved with the shocks being the correct length and therefore, the tabs are in the correct location.
By correct length, allanallen, we mean that the bottom of the shocker sits flush to the bottom of the bracket on the hub. Currently, this is 15mm inside the clamp, which cannot be right.
Posted 14th Dec 2014 at 13:40
luke89
Post #100
It also still begs the question what about the b4s make the car sit higher?
Posted 14th Dec 2014 at 13:54
