Author Subject: Compression test result not good
Marcdimma
I recently changed me exhaust and decat on my gti 6 but noticed it starts smoking when warm
Got me bit worried as I've just put a a new head on
Did a quick compression test with throttle closed and they were all on the 50 psi mark
I'm sure that's not good
Car runs good no lose in power just smokes when warm
Shall I be worried
Posted 23rd Feb 2014 at 16:56
eddy_gti6
Mine does similar but smokes a little when cold and when i give it some but then i am getting quite abit oil into my inlet through the breather. Time for an oil catch than i think. Take you filter off and see if there is much oil there
Posted 23rd Feb 2014 at 17:09
Marcdimma
I did find some oil in and around inlet and Thorttle few week ago when I took inlet off too change starter I'll put catch tank on see if it clears
Posted 23rd Feb 2014 at 17:14
A healthy engine should be somewhere around 190-200psi. Yes
Also, a compression test should be done with the throttle fully open to allow maximum air to intake.
Posted 23rd Feb 2014 at 17:26
Marcdimma
I'll give it another go with throttle open see if compression jumps up
Posted 23rd Feb 2014 at 17:49
pete-gti
:-) let us no what it says throttle open
You saying it smokes on tick over when warm?
Posted 23rd Feb 2014 at 17:52
Probably worn bores /rings / pistons. Common on these engines.
Leak down test would be better.
Posted 23rd Feb 2014 at 18:05
Are they? I didn't think worn bores were particularly common...
Posted 23rd Feb 2014 at 18:13
pete-gti
Mines about 15 years old, only puff of smoke is on very hard boot
Posted 23rd Feb 2014 at 18:15
Yes, that was my feeling too.
As long as they are looked after via regular oil changes and correct warming up from cold etc, they seem to go on forever. Yes
Posted 23rd Feb 2014 at 18:24
I thought they should be more like 200-220
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 23rd Feb 2014 at 18:40
As long as they are always in a carpeted heated garage, they seem to go on forever. Yes
Posted 23rd Feb 2014 at 18:41
woody.
Liking the edits recently buzz LOL
Posted 23rd Feb 2014 at 19:23
Marcdimma
Ye only smokes once it's warm
Dosent seem too smoke on tick over only when ya give it some
Or when ya cruise in a high gear
Posted 23rd Feb 2014 at 19:42
pete-gti
Piston rings, valve stem seals?
Posted 23rd Feb 2014 at 21:45
jeffers Forum Admin
What colour smoke Marc??
Team Running Engine again!
Team Negative Camber!
Posted 23rd Feb 2014 at 21:49
JWP EFi
Turbo Legend!
My engine is coming up for 190k, although it still makes power, one of my cylinders is a fair bit down, after a good hard run my dipstick pops out, when i previously had a catch tank there was ALOT of vapour coming out of the vent and the tank would collect nearly half a litre of oil after say an hours worth of hard driving, i now have my breathers plumbed back in as normal as the the cabin would be smelling of oil when the engine was hot.
If your compression is down it could well be that you have excessive bore wear/worn rings which in turn will pressurise the crankcase/sump therefore blow through into your throttle body. I would do another compression test but this time with throttle wide open and then do a leak down test. The leakdown will give you some obvious clues as to why you are down on compression.
Out of curiousity did you replace the head because it had been badly over heated, if so, excessive heat can cause the piston rings to lose their tension and hence not seal properly and cause the above
Posted 23rd Feb 2014 at 21:57
Marcdimma
The smoke is blue
I replaced the head because it was smoking blue I seen the valves from the head which has excessive wear on them from the guides my engineer suggested another gti6 Head which had good guides in replaced the valves and stem seals skimmed pressure tested
I checked bores when head was off didn't show Any signs off excessive wear
Posted 23rd Feb 2014 at 23:01
JWP EFi
Turbo Legend!
Although you might not have felt a wear ridge at the top of the bore they could be out of round further down on the thrust face. Try pulling the breather from the cam cover to see if theres excess vapour, seriously though, leakdown test is the way to go.
Posted 23rd Feb 2014 at 23:08
Marcdimma
Not done a leak down test before is it just a little oil in bore and do pressure test as normal with throttle open
I do have a spare block with 92000miles is there any way ov checking rings incase I do swap blocks over
Some1 timed it up wrong and bent all the inlet valves
Unless some has a known good bottom end
Posted 24th Feb 2014 at 11:05
