Author Subject: non starting
dannygti-6
Pulled and rallie out of the garage after two years storage ran when put away but now won't start seems to be an immobalizer fault any idears ?
Xbox Live = Sp4n
Team one gti-6 - 2 cherry rallye's
Posted 23rd Feb 2014 at 10:50
jeffers Forum Admin
Okay, first things first... is the fuel pump priming?
Team Running Engine again!
Team Negative Camber!
Posted 23rd Feb 2014 at 10:44
dannygti-6
No not at all suspecting black box under the dash or key un coaded am I thinking along the right lines ?
Xbox Live = Sp4n
Posted 23rd Feb 2014 at 10:51
Does the central locking work?
Posted 23rd Feb 2014 at 12:00
dannygti-6
Yer central lockings working buddy
Xbox Live = Sp4n
Posted 23rd Feb 2014 at 12:12
dannygti-6
Xbox Live = Sp4n
Posted 23rd Feb 2014 at 12:59
Have you tried the fuel cut-off switch in the engine bay behind the battery?
It's a red button, which may need pressing to reset the system. Yes
This will stop the fuel pump running too.
Posted 23rd Feb 2014 at 14:15
jeffers Forum Admin
Fuel pump relay, if it was the immobiliser it would prime the fuel pump but not allow spark. The relay is bolted to the back of the ecu box behind the battery, take it off and give it a smack. I had the exact problem after my car had been stored for about 18 month......Thumbs up
Posted 23rd Feb 2014 at 15:04
To check this, remove the relay and then bridge pins 5 and 8 on the loom multiplug, you should hear the fuel pump prime. Yes
Posted 23rd Feb 2014 at 16:07
Any update on this? Dunno
Posted 26th Feb 2014 at 07:09
jamesboard
Sorry, I can see this is an old post but I’m having issues with mine and I’ve changed the relay and also bridged the wires and the fuel pump then turns on. But I refit the relay and it won’t prime. It’s a brand new relay and I tested it anyway and it seems to work as it should.
Any ideas on the next steps?
Posted 9th Jan 2021 at 22:56
If its not priming and you've changed the relay on the back of the ECU Casing
Then it could be the pump it's self,.. Hmm
Posted 10th Jan 2021 at 19:41
He says if he bridges the relay then the pump primes...it sounds like you may have a dodgy relay even though it's apparantly new.
Posted 11th Jan 2021 at 21:05
