Author Subject: Refurbishing of calipers
speedo306
Can anyone provide me with pics or diagrams or steps as to how to refurbish the rear calipers on my 6.
RJ
Posted 22nd Feb 2014 at 13:50
it's ment to be a right bas**rd, can pick up refurbed units for cheap enough.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd Feb 2014 at 18:10
Handbrake mech is the pain in the arse bit by the looksDunno
But saying that I've just stripped and rebuilt the Sierra rear calipers for my kit car which alot of people say are a pain to strip and rebuild and I found it pretty easy Thumbs up
Got the rebuild kits from http://biggred.co.uk/
Finished product below after stripping/shot blasting/soaking in DEOX-C/painted with Rust Bullet/top coat of Rust Oleum.
So it is do-able if your handy with spannersSmile
Posted 22nd Feb 2014 at 22:03
oldbrownshoe
YOU'LL NEED SPECIAL CALIPER TOOL ( IN PUG THE DIRECTION IS OPPOSITE)
French military victories?
Did you mean French military defeats?
Posted 23rd Feb 2014 at 09:49
pugheaven
LOL no you don't, the above pic is tools that you use to wind the piston in but you can just use a large screwdriver shaft/allen key/flat bar etc...
As above the pain in the arse part is rebuilding the handbrake lever and shim mechanism the rest is simples!!
Posted 23rd Feb 2014 at 16:13
Niall
Tbh even thats not that difficult if you can find something to press down on the shims but thats the worst bit. Rest of it is easy.
Posted 23rd Feb 2014 at 19:58
rallyestyle
Anyone rebuilt AP 4 pots? Fancy giving mine a spruce up when i do the rest of the car Yes
Just Drive It
Posted 23rd Feb 2014 at 22:30
I stripped mine on Rallye and cleaned up/greased them.
very easy compared to other calipers I've done.
mine had no dust/crap seals though, have yours?
Posted 26th Feb 2014 at 11:13
i've got mine in bits now and you don't need any tools except a brake pipe spanner
i've got all the pistons etc out and got a new seal fitting kit so will try and get some photos
Posted 26th Feb 2014 at 11:32
rallyestyle
Thats a good question Dunno I dont think so No
Do you need any sort of special tool to get the pistons out?
Just Drive It
Posted 26th Feb 2014 at 18:07
daver6
I took the handbrake screw etc out and you can either push the piston out from the back or stick an airline in and blow them out
Wishbone Polybushes available
Posted 26th Feb 2014 at 18:30
rallyestyle
Airline, good call Thumbs up
Just Drive It
Posted 27th Feb 2014 at 16:02
with the face of the piston proud it'll just pull out with ease
Posted 27th Feb 2014 at 16:06
AP's don't have a handbrake mech in them!!!! Smile
Yeah airline shoots them out! Just get ready to catch them.
Posted 28th Feb 2014 at 12:05
Just put a block of wood between the pistons beforehand...
Posted 9th Mar 2014 at 13:20
finally dismantled all my rear calipers last night ready for rebuild with my new seals kit
simple mechanism for the rear handbrake really - a keyed cam with a tapered metal insert which sits in a track on the handbrake lever. then 5 dished washers and a flat washer which force the piston out. will attempt to rebuild them later on. heard a lot of people say the concave washers are a ballache and basically to not bother attempting it but am sure i can make some tools to do it Razz or alter my valve spring compressor to help. can't be that hard, right?! Unsure
Posted 8th Apr 2014 at 08:27
BIG water pump pliers do the trick I find.
Posted 8th Apr 2014 at 09:32
took me less than 8 mins to do both sides using a custom tool* i made and a pair of valve spring compressors. honestly don't know why people struggle when you can be innovative and make tools to help you out
* 21mm spark plug socket with 4 of the 6 sides cut away to make a prong to compress the concave shims
will post some photos when i've done all the seals and rebuilt properly
Posted 9th Apr 2014 at 19:08
I think I did mine in a vice and a deep socket as a press tool. Like Rikky says it's easy enough to come up with a working solution.
Posted 13th Apr 2014 at 23:14
