Author Subject: Jack for T reg Rallye
Mikedsp
Just realised car doesn't have a jack. Where should it be stowed please, and does anyone have one + wheelbrace please.
Ta, Mikedsp
Posted 21st Feb 2014 at 20:35
I have a jack or 2 somewhere I believe. If I can come across them I will be in touch. Also got a brace for sure as I came across that recently. They should be in the boot next to your lights.
  • Posted 21st Feb 2014 at 20:38
    scotzman
    If Dan can't find them I have both.
    Posted 21st Feb 2014 at 20:44
    Mikedsp
    Fantastic - pls let me know how much, Thanks, Mike dsp
    Posted 21st Feb 2014 at 20:57
    aaron6
    The standard braces are w**k. They bend too easily. Get yourself a nice telescopic one.
    Posted 22nd Feb 2014 at 07:16
    Yup I've got same sort of telescopic one works much better. Also you do need the original brace to wind the spare down or at least something similar.
    Posted 22nd Feb 2014 at 07:52
    mik
    To add a bit of detail, it clips in beneath the boot lip between the rear lights. A bit of a PITA to do, but it does go in there. Yes it is not the best quality, but if it is in good nick it will be OK for what it is designed for - changing a wheel by the side of the road a handful of times in the car's life. It most definitely is not designed for doing DIY on the car. My car came without either and I found a new jack and brace on ebay pretty cheap. Again, the wheel brace is not good for repeated use such as DIY stuff, as they aren't designed for it. I wrecked one attempting to undo over-tightened rattle-gunned wheel nuts.
    Cherry Rallye SOLD
    Posted 22nd Feb 2014 at 13:28
    RetroPug
    For wheel nuts get a proper breaker bar and carry it with you... you'll be glad you did if you ever need to change a wheel. They're not expensive at all, I've got a proper, huge ratchet one and it was 20something pounds iirc.
    I don't think I've ever come across an OEM wrench that was too small for good leverage and generally not ideal.
    Posted 22nd Feb 2014 at 10:23
    pete-gti
    Still after one?
    Posted 23rd Feb 2014 at 17:56
    I've sorted him out Smile
  • Posted 23rd Feb 2014 at 23:15
