displaying posts 1 to 2 of 2
Author Subject: brembo line size
6waysforward
I have some clio/megaine 4 pots but need some hoses to suit a 6.
What length and ends do they have?
I am going to order some from custom hoses but i need to know what banjo's etc etc.
Thanks.
Posted 15th Feb 2014 at 18:29
Niall
Slightly off topic but i can't recommend custom hoses enough!
Anyway, i ordered my hoses from them for my Highspecs which i would imagine will be the same length as the ones you require (depending on what disc size your using?). Im using standard discs and if anything, the hoses are slightly too long but doesn't cause an issue.
These are the specs of mine when i ordered them
Options:Fitting 1: Swivel Female M10 x 1.00Fitting 1 Angle: StraightFitting 2: Banjo M10 or 3/8"Fitting 2 Angle: StraightSupport 1: Rubber GrommetSupport 2: ChooseColour: Transparent BlueFerrules: Black HeatshrinkLength: 600mm
Posted 16th Feb 2014 at 18:18
