Author Subject: Engine Temp
Mikedsp
Hi All,
new to 306 Pugs (but not motorsport) and need a steer please. Recently aquired Rallye 306 runs v. cool. Tested thermostat and all seems OK - any ideas please? I did wonder if there was more than one spec for the temp sender.
Thanks,
Mikedsp
Posted 15th Feb 2014 at 14:30
jeffers Forum Admin
How cool matey?
Team Running Engine again!
Team Negative Camber!
Posted 15th Feb 2014 at 14:34
eddy_gti6
Mine runs around 80oC or just slightly lower when driving normal and raises to around 90oC when im giving it some for a long period of time. Oil doesnt get too high either but that could be down to my oil cooler.
Posted 15th Feb 2014 at 14:41
Mikedsp
just getting onto the clock, so 70 deg (ish), rising a bit if driven fast for a while to 75 / 80 deg Previous owner said it gets up to 90ish if stuck in traffic when fans cut in. I would just expect it to run a bit warmer? Oil temp gets to 1/3 way up clock so engine is def getting warmish. Maybe stat is not closing fully.
Posted 15th Feb 2014 at 15:54
The blue temp sensor could be up the spout or the stat is opening to early. Fans cut in low speed or high at 90?
Posted 15th Feb 2014 at 16:16
pete-gti
Dodgy thermostat I had same problem few years back
Posted 15th Feb 2014 at 17:40
woody.
Would running cooler affect the mpg at all?
Posted 15th Feb 2014 at 18:01
Yep, agreed.
I had a dodgy thermostat years ago, which made the engine run at 70c when I was moving. It was a cheapo factors one, I replaced it with a Pug one and it's fine 5 years later. Smile
Posted 15th Feb 2014 at 18:02
Mikedsp
All good stuff - many thanks. I'll change the stat for starters and see what happens.
Also - how on earth do you get the plastic connector out of the stat housing to make it easier to get at the stat. I took the clip off and used LOTS of wellie on the hose and it didn't even look like budging. Didn't want to break it so just left it on. Cheers, Mike dsp
Posted 15th Feb 2014 at 18:31
pete-gti
Just unbolt it mate, need to remove the hose
Posted 15th Feb 2014 at 19:40
pete-gti
Posted 15th Feb 2014 at 19:42
Rich E Forum Admin
A few degrees won't make a difference but the ECU uses the coolant temperature to decide cold running mixture enrichment so significant over-cooling will affect fuel consumption.
Posted 15th Feb 2014 at 22:04
Mikedsp
Thanks, good advice. Changed stat for a decent quality (non OEM) stat and now runs 80 ish, but thats in quite a cool feb evening.
Posted 24th Feb 2014 at 19:06
RetroPug
That's a normal temperature Smile
Posted 24th Feb 2014 at 19:09
pete-gti
About right :-)
Posted 24th Feb 2014 at 19:10
The stat is an 83c one, so sitting at 80ish on the gauge is about spot on. Smile
Posted 24th Feb 2014 at 20:27
woody.
Thanks Rich
Posted 25th Feb 2014 at 20:29
aaron6
Good temperature. I'd be inclined to run it upto 97 degrees and check the fans work etc.
Posted 25th Feb 2014 at 22:07
