Author Subject: Wipers
crazydave
Hello all my wipers do around 6 wipes on auto and then park wherever they want. This also applies if I just clear the screen they do not return to the park position. The wipers function perfectly on all other modes.
Is this the motor relay or rain sensor has anyone had this before.
Cheers.
Posted 1st Feb 2014 at 16:08
I've never had this personally, but I'm pretty sure from memory when others have experienced similar issues to this, the wiper motor itself was at fault.
Posted 2nd Feb 2014 at 21:39
pete-gti
Be the motor :-)
Posted 2nd Feb 2014 at 21:42
Motor.
Highly likely that the scuttle drain hole is blocked and the motor has been sitting in a pool of water.
  • Posted 2nd Feb 2014 at 21:43
    crazydave
    Cheers guys I checked and its free from water drain is clear. It comes and goes the fault thought it was the motor glad to know guess seems correct.
    Cheers again Thumbs up
    Posted 3rd Feb 2014 at 18:50
    doon1988
    Did you sort this Dave?
    I have the same issue whereby if I put on auto they just stop mid screen (sometimes they stop in the right place but not often)... Also as you say if I use the manual one sweep then as soon as I let go of the stick - the wipers stop so I have to hold it in the whole way.
    The middle option works fine but again on the fastest setting this does about 5 sweeps then stops...
    Posted 28th Feb 2014 at 14:09
    Cjwatson27
    Mine does this some times i just unplug the motor 2 or 3 times and its fine for months , tho mine not full of water it looks like it gets a fair bit in there ,
    Posted 28th Feb 2014 at 16:58
    doon1988
    cool i'll give that a go.
    Posted 28th Feb 2014 at 19:12
