The car used to fire up as soon as i turn the key but since i have supercharged it, it can take a couple of mins to start. When the battery is low it just kills itself.
Anyhow I just got a new battery for it.
I just did an amp check by removing the earth and putting my multimeter inline. Car was locked and alarmed at the time. My readings were 0.11-0.16 on the 10A setting of the mutlimeter.
When i first put it on it reads 4.16 but then instantly drops to the above figure.
I have disconnected the alarm and the amp in the boot but readings are the same suggesting they are not causing a draw.
Not sure if this is good or not?
When i connected the multimeter inbetween the earth and the battery the starter motor solenoid clicks and engages the flywheel but does not try and start the car? Is that right?
Any ideas???
***Breaking*** Ph3 Silver GTI 6 High Boost
6waysforward
