Author Subject: Aircon removal
Cjwatson27
Hi I'm having my engine swapped to a gti6 which is proving more hassle than the cars worth , in both cars the airconditioning pipes a badly corroded so the garage is saying to do away with it , ive heard that the rallye set ups hard to come by is it possible to make somthing up and has anyone done this before ?
Thanks for any input Thumbs up
Posted 22nd Jan 2014 at 21:55
jeffers Forum Admin
You can buy the parts for a rallye aux setup off ecp. As long as you can provide the pug part numbers they'll match it. Thats what i did for my track car. In some ways in my opinion its a better option than getting a secondhand setup as most will be getting quite worn these days. Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 22nd Jan 2014 at 22:04
Cjwatson27
Ok cheers dont supose you know the numbers do you ? The mechanic was on about making one with a shorter belt and parts robbed from the xsi auxiliary belt system
Posted 22nd Jan 2014 at 22:39
jeffers Forum Admin
Gimme ten mins i'll try find them.....
Posted 22nd Jan 2014 at 22:42
3gan
i am removing the pump from my gti6 as the air con rad has been removed but unsure what route to take I just thought it would have been buying a shorter belt?
Ill keep an eye on this thank you
Posted 22nd Jan 2014 at 23:07
You can buy a kit off eBay for £100 but be carefull to clean out the threads on the bolt hols as 1 is not used in the gti6 set up
Posted 22nd Jan 2014 at 23:16
jeffers Forum Admin
^^^ This, use an m8 tap, if you use a bolt it'll likely jam and snap. As for the part numbers i'm struggling at the min. I'll find it just bear with me! Thumbs up
Posted 22nd Jan 2014 at 23:22
Cjwatson27
Thumbs up Cheers
Posted 23rd Jan 2014 at 06:58
