Author Subject: Power Steering Fluid Leak after top mount change
demondriverdan
The car has started leaking power steering fluid since I put the camber adjustable top mounts on along with the strut braces. The leak only happens when the steering is turned, I can see from the fluid drops on the floor.
I'm thinking that by adding the top mount camber, the hub is slightly further away from the ram causing a seal breaking or something? Possibly should be able to remove it by winding the TREs out a bit?
Rallye Race Car
Posted 20th Jan 2014 at 21:44
scotzman
Adjustable top mounts will bring the hub in if they are adjusted for -ve camber.
Posted 20th Jan 2014 at 21:46
demondriverdan
I thought it would angle the bottom of the hub out?
Rallye Race Car
Posted 20th Jan 2014 at 21:58
scotzman
No, the pivot is the ball joint, which is at the bottom of the hub, you move the top mounts in to give -ve camber which will bring in the hub very slightly too.
Posted 20th Jan 2014 at 22:07
demondriverdan
Of course, that makes sense. There goes my genius plan for an easy solution!
Rallye Race Car
demondriverdan
Bit of a bump, seems the fluid leak is coming from the ram itself. Bit of a PITA really
Rallye Race Car
Posted 16th Feb 2014 at 23:30
