Author Subject: Cable/Clutch??
mellowr1
Yo Dudes!!
Question for you experts..........
My car had a new Valeo Clutch just over a year ago,but has not done many miles. The pedal has always been stiff at the top inch of travel, as it returns to release position,which is a bit of a pain in stop start situations. Also, when in stop start situations it sometimes ends up losing feel and only has about an inch of working pedal to engage clutch, but then after a while goes back to full pedal use. There is no slipping either.
Last night however it only had said inch or so of clutch pedal use and gear change was difficult and i wasnt in stop start situation. I had a press of clutch again today and it was better again. The pedal returns fully, there's just a sloppy clutch pedal. its like slack in cable is not being taken up Unsure
So, the million dollar question.....Cable Or Clutch??Dunno
Posted 13th Jan 2014 at 17:40
astor gray 2014
That sounds like your slave cylinder air is trapped in it just needs to be bled if you are handy with cars you could do it yourself
Posted 13th Jan 2014 at 17:59
Niall
306s don't have hydraulic clutches.
Try pressing the clutch as far down as possible then slip your foot off the side so the clutch pedal jumps back up. Some times this can reset the auto adjuster but in all honesty, that sounds like what happened with my 1.8 when i first got it and that needed a new pressure plate Sad
Posted 13th Jan 2014 at 18:03
I'd try a clutch cable first mick and remove the return spring from the side of the clutch pedal as it can cause the stiff top part of pedal movement.
Cables are about £30ish if it doesn't cure it then something like one of your pressure plate springs is broken but that's unlikely.
Posted 13th Jan 2014 at 18:33
mellowr1
fancy a job armz?Dunno
Big grin LOL
Posted 13th Jan 2014 at 19:31
Got a gearbox clutch and cable to do on Amins Rallye, need to sort the clutch on the Leon as it slips since remap... I won't have time to do it for a couple of weeks mate depends how desperate you need it done? Maybe next weekend?
Yours got AC or not?
Posted 13th Jan 2014 at 19:43
mellowr1
Yeah Its Got Air Con Mate,Not That It Works Lol.
Il B WoRking The Following Weekend. Il SeE HoW It Goes N Possibly Get A CabLe And If I Get Stuck Il Have To Havr A Go At Fitting itSmile It
Il Let U Know Mate If I Get Really Stuck cheersThumbs up
Posted 13th Jan 2014 at 20:10
I can fit you a clutch cable Mick, although you're a bit of a drive. Yes
Posted 13th Jan 2014 at 21:35
astor gray 2014
Silly me
Posted 13th Jan 2014 at 21:55
mellowr1
THANKS STANThumbs up i thinkLOL
I could probably do it, just had my days of laying under cars, especially at this time of yearSmile
Posted 13th Jan 2014 at 22:20
Maybe we could work something out if I was down your way? Dunno
Posted 13th Jan 2014 at 23:03
mellowr1
U Intendin Bein Down Here Soon Then Stan?Dunno
Posted 14th Jan 2014 at 10:23
You never know mate, I go all over.
Posted 14th Jan 2014 at 13:00
mellowr1
well you let me know when you're down here mate and il let you know if i have done it or notThumbs up LOL
Posted 14th Jan 2014 at 17:03
Ok mate. Smile
Posted 14th Jan 2014 at 19:51
Just turn the stereo up Thumbs up
Posted 14th Jan 2014 at 22:57
mellowr1
and that would solve the lack of clutch how mate?Unsure Dunno
Posted 14th Jan 2014 at 23:43
Battery drain should soften the feel of the release bearing.
  • Posted 14th Jan 2014 at 23:44
    mellowr1
    Peugeot Showin Two Cables For My Car,One With Extra Bush,Anyone Know Which Cable I Need As Parts Bloke dontUnsure
    Posted 15th Jan 2014 at 09:02
    mellowr1
    seem to have fixed this by "jiggling" the cable where it exits from self adjuster to gearbox. new cable is sat here waiting though just in caseThumbs up
    Posted 18th Jan 2014 at 15:09
    It won't last for long unfortunately Mick, the adjuster will be seized due to the exhaust manifold drying out all the grease within it. Yes
    Posted 18th Jan 2014 at 18:27
    mellowr1
    Lasted Ok So Far,Works Like A Dream Lol. New Cable Waitin To Go On If And whenThumbs up
    Posted 18th Jan 2014 at 20:34
