Author Subject: Sold - Piper BP285H cams
Denis
Piper BP285H cams - Taken out of cylinder head that I bought.
Comparison between Piper and standard Pug inlet profiles:
£300 + delivery
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 30th May 2014 at 21:48
JWP EFi
Turbo Legend!
would these work with pocketed o/e cast pistons and o/e valve gear?
Posted 12th Jan 2014 at 22:03
Denis
As far as I know, standard cams have lift of 0.8mm at TDC. Piper specifies timing of 1.83mm of lift at TDC. So with making piston pockets 1mm deeper, they should work on standard pistons.
These cams are for use with hydraulic lifters (H - in the in the name, not be confused with just 285 - which require solid lifters).
WhiteBMW M140i
Posted 12th Jan 2014 at 22:32
JWP EFi
Turbo Legend!
Pm on it's way mate
Posted 12th Jan 2014 at 22:35
JWP EFi
Turbo Legend!
other than requiring solids what exactly is/are the diffrences between 285H and just 285?
Posted 12th Jan 2014 at 22:46
Denis
Completely different profiles: link
WhiteBMW M140i
Posted 13th Jan 2014 at 00:15
hepkem
I checked your project thread and you use PT81. Piper BP285H are similar to PT81 so I guess I can get similar performance compared to your setup ?
Do you use standard pistons in your setup or aftermarket forged items with PT81 ? It's written that standard pistons have to skimmed 1mm. Which aftermarket pistons will be compatible with BP285H ?
1999 Xsara VTS ITB
Posted 21st Jan 2014 at 18:48
Denis
Yes, BP285H are very similar to PT81. As I already have PT81s - I don’t need these.
For pistons, the easiest thing is to modify standard pistons by deepening valve cut-outs. As far as I know, 1mm is the maximum that can be done safely and provides enough space to time up these cams.
For aftermarket pistons, off the shelf - Wossner; custom: Iasa, JE, Wiseco.
WhiteBMW M140i
Posted 21st Jan 2014 at 22:18
Denis
Bump
WhiteBMW M140i
Posted 17th Feb 2014 at 21:50
