displaying posts 1 to 25 of 50
Author Subject: blower stopped? SOLVED
darkgti6
Hello all, so over the past year my heater blower has had a mind of its own. Intermittently stopping from time to time sometimes for a few minute's then coming back on again without warning.
Tonight its finally stopped for good I think. Its showing no signs of life.
I dont think its the fan itself as this was replaced in early November for a brand new oe unit and the fuse is ok so it must be the green relay. Now I didnt know what one it is so I took them all out 1 by 1 to see if I could see any burning but everything looks ok?
Is it possible the relay has failed internally without anything noticeable on the outside of the unit? Also what is the location of the relay in question? Mine is a phase 2.5.
Any advice welcome Smile
Chris.
Team Peugeot Sport 308 Gti�
Posted 9th Jan 2014 at 21:51
green relay every time, melting
Posted 16th Dec 2013 at 21:23
darkgti6
Which one is it rikky? Shall I upload a pic?
Posted 16th Dec 2013 at 21:25
eddy_gti6
If you need a blower motor let me know i have a couple mate Thumbs up
Posted 16th Dec 2013 at 21:32
darkgti6
Re read my first post please.
Posted 16th Dec 2013 at 21:37
darkgti6
Is it relay A B or C?
Posted 16th Dec 2013 at 21:45
Kick f**k into the underside of the blower motor itself before pricking around with relays especially if you pull the green relays out and they haven't melted...
Posted 16th Dec 2013 at 22:37
darkgti6
Its a brand new oe heater motor. Just went out and plugged the old one in and thats not doing anything either. Also swapped all the green relays around and thats not done anything either.
Wtf is wrong with it?
Posted 16th Dec 2013 at 22:40
is there power on the aircon lights?
Posted 16th Dec 2013 at 22:43
darkgti6
Yup everything else is working. Air con switch - everything. Just no blowerAngry
Posted 16th Dec 2013 at 22:48
darkgti6
Of course, it would break when its raining and the cars full of damp. FML.
Posted 16th Dec 2013 at 22:49
aaron6
When mine had the symptoms it was the green relay. Check posts started by me. I changed the motor, control console then relay. This stopped it though.
Posted 17th Dec 2013 at 07:14
aaron6
http://www.306gti6.com/forum/showthread.php?id=150664
Posted 17th Dec 2013 at 07:17
darkgti6
Ive swapped all the green relays around as said in post number 8. Everything else still works / illuminates. No duff fuses that i can find. Just no fan. This wasnt even funny this morning.
Ive checked to see if ive got voltage at the connector to the fan unit itself and im getting 12v between red and black and something like 7 volts on the third blue lead.
Posted 17th Dec 2013 at 08:13
darkgti6
Ok been out with the beefy work mega meter. Red and black is saying exactly 12 volts. Red to the centre blue wire is 12 volts with fan on zero position the drops bit by bit with each turn/click of the fan control until its on maximum and registers as 7.5 / 8 volts.
This doesn't make any sense. I have voltage all over the connector and the fan isnt moving.
The only thing I can come up with is the connector itself isnt making adequate contact. All the connections look black and manky. I did give it a wiggle but I still didnt get any movement.
Posted 17th Dec 2013 at 08:33
tried kicking the base of the fan? that sorted my HDI one when i first got it, although i've had relay problems in the past but you'll have no lights whatsoever on the fascia (aircon, recirc.)
Posted 17th Dec 2013 at 08:46
darkgti6
Listen mate I am not booting the bottom of a brand new genuine fan unit. Im gonna try cleaning up the connection.
Posted 17th Dec 2013 at 09:31
aaron6
LOL
Yeah, try cleaning the terminals on the motor if you've checked for burnt relays.
Posted 17th Dec 2013 at 13:12
darkgti6
aaron6 wrote:
LOL
Its not the motor terminals but the connector. The metal contacts look disgraceful. Providing there is no current when the ignition is off im gonna soak the whole connector on coca cola to clean them up. I think my problem lies here.
If this doesn't work tben I will put on my best angry face and boot the underside of itWink
Posted 17th Dec 2013 at 13:49
Kicking it sorts them 99% of the time - barefoot obviously.
Don't do what I did and pierce the bas**rd with a winkle picker.
  • Posted 17th Dec 2013 at 13:50
    dangypsyshoes6
    my heater didn't work after a boot but when my mate kicked it it worked fine. must be the size of the shoe. i'm only a size 4 so presume there wasn't enough weight
    Posted 17th Dec 2013 at 13:57
    aaron6
    Size 10 FTW
    Posted 17th Dec 2013 at 15:06
    aaron6 wrote:
    Size 10 FTW
    If you're a child yeah.
  • Posted 17th Dec 2013 at 15:24
    darkgti6
    aaron6 wrote:
    LOL
    Posted 17th Dec 2013 at 15:32
    darkgti6
    aaron6 wrote:
    LOL
