Author Subject: Throttle Bodies - Satchell/Long inlet.
bazgtmi
These are the highly sought after earlier & in my opinion much better design TB's on a proper length inlet as designed & built by Colin & Sandy, including nice long trumpets incorporating an ITG filter backplate.
These are the simplest way to gain a proper length inlet setup on a 16v XU, without bonnet/major slam panel mods. Includes throttle position sensor & uses standard fuel rail & throttle cable enabling simple fitment. They have barely been used since being put together and sound absolutely amazing!
£750
I'm in Herts on the Essex border between M11 j7&8 or could send via insured courier at cost.
Email; b7bpt@hotmail.com
205Parts@uk7.net
Posted 16th Dec 2013 at 17:20
Roon
Are these literally just bolt on and go? Does it require mapping once fitted.?
Posted 16th Dec 2013 at 18:28
Roon
Ah yes they do Sad
Posted 16th Dec 2013 at 18:37
jammapic
But you can get a map from Wayne Scofield 07874328306, on your stock ecu with them. You can take the car, or send the ecu to him.
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 16th Dec 2013 at 18:52
7057sam
JP
Is this the map he made for you on standard cams?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 16th Dec 2013 at 21:05
jammapic
Yep, the very same
Posted 17th Dec 2013 at 08:50
gman
Are these earlier ones based on bike bodies?
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 17th Dec 2013 at 13:21
allanallen
They're the earlier lotus bodies by the looks
Facebook
Posted 17th Dec 2013 at 13:56
markylee
Hi what bhp did you get with these bodies
Posted 17th Dec 2013 at 14:06
bazgtmi
Hi, no they're the earlier, much better ones using an OEM manufacturers bodies. Latterly they used bike bodies which by all means are very much a heath robinson affair that people have many issues with balancing & sealing.
205Parts@uk7.net
Posted 23rd Dec 2013 at 14:19
bazgtmi
That wholly depends on many factors. The engine they're from made around 230bhp.
205Parts@uk7.net
Posted 23rd Dec 2013 at 14:22
dcc
Bazzler, are they dcoe pattern?
205 GTI
Xsara HDI
Posted 23rd Dec 2013 at 23:55
bazgtmi
Pretty sure they are yes, I was going to put them on my carbon 8v inlet but never got round to checking tbh! I'll have a look!
205Parts@uk7.net
Posted 24th Dec 2013 at 00:02
footah212
So these literally bolt straight on to the head , remapp the standard ecu and bobs yer aunty?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 24th Dec 2013 at 10:50
gman
They would have to be mapped by someone who can map the standard ECU, i.e. Wayne Schofield @ 500 quid a pop, unless you go down the standalone management route which would be a better choice and allow easier adjustment.
You won't see much power gain without aftermarket cams, but you will get better throttle response, noise and midrange. Provided they are mapped well of course.
2002 Audi S3 (Sold)
Posted 24th Dec 2013 at 12:49
bazgtmi
You would see a worthwhile gain with these, better than a shorter setup.
205Parts@uk7.net
Posted 24th Dec 2013 at 13:28
pete_rallye
Any idea what diameter they are?
Lap of the 'ring
Posted 24th Dec 2013 at 14:45
jammapic
Says who you won't get a decent gain on standard cams? I gained 28hp on stock cams with throttle bodies and just a simple £300 Chip Wizards map....
Posted 27th Dec 2013 at 23:36
bazgtmi
Sorry for the late reply! They're 45mm.
205Parts@uk7.net
Posted 3rd Jan 2014 at 14:22
bazgtmi
Agree with the above i think you've been mis-informed, probably by someone persuading you to buy their SC setup...? Razz Thumbs down
I've always seen worthwhile gains with bodies alone on many engines, a couple of circa 185bhp standard Mi's, definitely gained on my Longman 8v even over it's previous carb setup & i have a 187bhp rebuilt GTi6 with std cams. Also, for the record which might be of interest to you gman, my current boosted 205 is certainly less fun than any of my bodied NA 8v & 16v cars! Yes
As said, Wayne(Chipwizards) will also map your std ecu for less than your quoted figure, certainly worth considering if on a budget, although of course no doubt a proper Ecu would be more ideal.
Here's a similar set on a 306... Cool
bazgtmi has attached the following image:
205Parts@uk7.net
Posted 3rd Jan 2014 at 14:39
7057sam
Can't believe these haven't sold.
got to get rid of my cage, seats and harnesses before I put in a offer.
Rallye dead Sad
Posted 3rd Jan 2014 at 15:17
bazgtmi
For sale again.
205Parts@uk7.net
Posted 13th Apr 2014 at 17:30
axnxdxy
Are these still available?
Posted 19th Apr 2014 at 12:52
bazgtmi
They are!
205Parts@uk7.net
Posted 20th Apr 2014 at 02:03
bazgtmi
Still available, my membership is expiring soon...
205Parts@uk7.net
Posted 25th Apr 2014 at 14:30
